Question about Polaris 3900 Sport Pool Cleaner ()
SOURCE: Older Polaris doesn't sweep
pantera ll by wicor sand filter distributes the sand back into the pool, what could the problem be?
Posted on Jun 02, 2009
SOURCE: polaris 380
polaris has belts in side it if your handy you can replace them your self if not any pool place can do it but it is a belt i have a 380
Posted on Jul 26, 2009
SOURCE: My Polaris pool cleaner doesn't seem to have
I went to another site in my search for an answer to my problem...it cost nothing.
Posted on Aug 16, 2009
SOURCE: polaris in pool cleaner back water single spout not water passing
Check your wheel RPM. With these automatic pool cleaners, you can manually adjust the RPM. Low RPM could be the cause of the problem. To check the RPM, first mark a single wheel side tire, Turn the pump on, hold the cleaner under water and count the wheel revolutions for one minute. If the RPM is less than 28, you might need to remove the blue restrictor disk from the UWF or adjust the gate valve on the booster pump. Also, this may sound simple, but make sure there is no debris lodged in the wheels/axles. Check your filter screen in your in-line filter and make sure that it is clear of debris. You will also want to check your hoses, connections, and swivel to make sure that there are no leaks.
Posted on Jul 21, 2010
SOURCE: where in the feed hose do you put the backup valve
About 18" to 3' up the hose from the head.
Posted on Oct 10, 2010
