First of all insert the sim which is working currently and follow the instructions to generate your code.
1.
Downoad [ANT] Simple Ant Simple.zip 2. If you
have Nokia PC Suite running, be sure to close it by exiting from the taskbar
icon. 3.
Extract [ANT] Simple ] and run Simple.exe located in the folder 4.
Connect the phone via USB to the computer by selecting Pc suit/Ovi suit when
prompt a message in your pone. 5.After
you've connected your phone, Click "Read Info" 6. On the
MAIN tab, click on GET. Your phone IMEI number and model should be displayed on
the bottom panel as shown below 7. Now
click on the SERVICE tab and click on GET button under USER CODE 8. Your
security code should now be displayed on the right side of the application
window. And here if you could not understand How to Generate Your Phone Security code..Only for Nokia bb5 Thanks For visiting Fixya
try the default codes like 12345 or 00000. if they didn't work our you can go with resetting your phone. You can reset your security code through master reset codes. You can get the master reset codes from Unlocking4Free.com.
