Question about RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
How do I get a RCA modem to run in Ubuntu Linux? The modem works in XP, just fine.
Posted by aclark26 on
none
    Sergeant:
  • 137 Answers
There are no drivers to operate the modem as a USB device. Using a crossover cable (one should have come with the modem), you should be able to connect to it via the Ethernet ports on your computer and the modem.
Posted on Sep 25, 2011
How to activation camera in ubuntu os
UBUNTU is a linux open source OS. Chances are your camera doesnt have a Linux driver and wasnt designed to operate under Linux. The website http://www.ubuntu.com/support/communityis the user support community for UBUNTU.. I would post your question there for assistance from someone with a similar model for your laptop. There is also a selection for real time chat support from other UBUNTU users. I have checked DELL website under your unit and it was made to run the Windows XP system so there are no Linux drivers available directly from Dell.
Jun 06, 2010 | Dell Inspiron 1000 Notebook
H9601C prolink modem driver
i cannot install prolink h9601 adsl modem on windows xp home edition,, any luck??????
Sep 02, 2009 | D-Link DFM 562IS (DFM-562IS) Modem
Ubuntu cant access/save files.
Hello my friend thus your Grubber still functioning? If still works then try to access your XP by selecting Xp in your grubber. Or if you can't access your XP files within the Linux you need to select and open first the XP platform. If you can't find the XP loader or platform or it doesn't starts the XP then it is possible that your XP is overwrite by your Linux platform or some error in writing the linux installation to your XP platform. Will if that is happening right now the only way to regenerate your Xp is to reinstall your XP then after you reinstall it need also to reinstall your Linux otherwise after reinstalling Xp it will overwrite your Linux system will lost forever.
Hope this solution helps your pronblem. If you need more assistance you can reply to this post. Thank you
Jul 07, 2009 | Computers & Internet
Vista & rca lyra rd2780
If you boot with the RD2780 plugged into the USB, Vista will recognize it.
Jan 27, 2009 | RCA Lyra RD2780 Digital Media Player
Armada M700 & Linux XP 2006
Yes I used the latest version of Ubuntu Linux.
Get it here
Ubuntu 8.10
You will need to install NDIS in linux after the install to use the windows drivers for your wireless card if you have one. Sometimes older wireless cards will work but most of the time you need the NDIS to use the windows disk that comes with your wireless device(if you are using one) Your hard wired ethernet port should be detected automatically as well as all your other drivers(since the machine is old)
Good luck..if you need any more help I will be around. No other compatibility issues exist, and it will run a lot faster than XP. I would suggest 512MB of Ram but 256 will handle it fine.
Oct 14, 2008 | Compaq Armada M700 Notebook
USB mouse won't work under XP in a dual boot Ubuntu GRUB 1.5
It has the latest mouse driver (logitech setpoint 4.0). Before installing Ubuntu the setup worked w/ SUSE/XP using GRUB dual boot. After installing Ubuntu XP does not see the usb mouse. Even Logitech setpoint does not have the mouse setup/configuration option. It appears that at boot it does not recognize the mouse or disables it. The BIOS has the usb keyboard and mouse enabled. Currently, I have two mices one for xp and either mouse will work under Ubuntu.
Sep 03, 2008 | Canonical Ltd. Ubuntu
Install modem in ubuntu desktop
downlod driver for linux it is also avilable dlink website
thanks
Nov 19, 2007 | D-Link DFM 562IS (DFM-562IS) Modem
RCA DCM425 DIGITAL CABLE MODEM (RCADCM425) Logo
116 people viewed this question
Top RCA Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
