Cell Phones Logo
Posted on Sep 01, 2011
Today my brother received 2 txts, supposedly from me, both similar saying "hope you feel calmer, had a great night last night, you need to go to Specsavers". and sender was Mary Cheney - but without my no. He is a very ill person and was most upset by this, and so am I as the txts did NOT come from me. I've contacted Specsavers and they are not responsible. PLEASE can you explain this situation as soon as possible. My brother lives 200 miles away from me and finds speaking, and texting now impossible - so his wife deals with this. It has been a most upsetting morning for all. I realise you need my brother's no. which I feel reluctant to share - so if possible can it be searched without? I am an Orange user.
Veena Solomon
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Sep 01, 2011
Veena Solomon
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
1474
Points
47
You are a victim of spoofing.. There are many ways to send fake text messages from anyone's number. Just search the internet for sms spoof and you will know
Where can i found a manual for the brother knitting machines kh 212
Well I found the manual for the KH210 (picture from that manual below), it may be similar but not sure.
https://app.box.com/shared/3g5d0rq9q7/2/73526225/657550011/1
is the site. If it doesn't come up, then start here
then click on Brother, then Knitting Machine and it is next to last on Page 2 of this section.
Hope this helps. As I did get to look at it, the carriage is set up very similar to their plastic KX350 machine, so the levers on the side will be the same but will be more sturdier than the plastic bed.
I have a yamaha RX-4659 receiver and my Zone 2 (outside speakers) had been working great for the last 3 summers. Now, I am unable to get any music to my outside speakers. When I try to adjust volume for...
Zone 2 has been switched to "EXT" in the setup menu. Switch it to "Amp" or "Int" and it should be fine. It thinks you are using an external amplifier. If you need further help, post a reply and I will help you further. Hope this does the trick for you!
1helpful
Power substation blew up last night, which meant flickering lights, and low power (extremely weird). Today I have power -- finally -- but I can't reset my oven like I usually do when there is a power...
You have a defective touch pad(stuck button) probably from the surge that happened last night. to access this you will need to disconnect power and remove the back upper panel. Usually four screw hold on the board. Make sure when you are changing the board swap wire for wire to ensure correct install.
Part Number: 3191645
My model is RX-V665...not sure what the BL stands for... anyway...no sound from the subwoofer. Pull the RCA wire from the back of the receiver and touch it with my finder and you hear a buzz from the...
HI,
first of all select ur sub woofers auto mute (auto power off ) switch to off position.
then connect the mic and calibrate ur system one more time. after calibration select it to on position. u will surely get it work. if need any further assistance feel free to contact through fixya.
ok
GOT A BRAND NEW C3050. wORKED perfectly last night and today saying "Emergency calls only". Says £10 credit.
Sounds like a problem with the SIM Card. Try to remove it, clean it (soft cloth) and put it back in.
3helpful
2answers
Spring unattached on Brother LS-1217 near bobbin
Check out this site. There is pictures of each machine there. All the Q&A answers in simple language, as well as a GREAT cust. support. (its a Brother after all!)
I found download manuals there as well.
http://welcome.solutions.brother.com/bsc/public/Model_list.aspx?reg=us&c=us&lang=en&titleid=36
I hope this helps! Thanks for keeping the Art of sewing going!!!!
Happy sewing!
2answers
Can't find my manual.......
THIS is a link explaining how to set distinctive ring tones. You can download the user manual HERE.
You will need Adobe Reader to view the document. Download it HERE for free.
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. – I would greatly appreciate a FixYa!rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Top Orange Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you an Orange Cell Phone Expert? Answer questions, earn points and help others
