I WANT TO KNOW WHERE ON THE COMPUTER DO i INSERT MEMORY CARD TO VIEW MY PICTURES
Posted by lmaxit2 on
Chris Hingee
  • Computers & ... Master
  • 32,281 Answers
If there are no memory card slots on your computer, then you need to purchase an USB memory card reader. Insert the memory card into the USB reader and then plug the USB memory card into the USB port in your computer. The computer will see the memory card as an external storage device, you can then open the folders and photos on the memory card yo view and copy them to your computer.
Posted on Sep 01, 2011
Anonymous
    Master:
  • 382 Answers
Use card reader inorder to insert your memory card on the computer.
After inserting memory card in printer, how can you view pictureson your computer?
With the printer turned on and connected to the computer, once you insert the memory card, it should show up as a removable drive in Windows Explorer. Click Start and then Computer. This should show you a dialog displaying the drives accessible to the computer The memory card should be in this list.
1helpful
The play back button of my nikon coolpix s200 is not working. i don't know how to fix it. please help me... i cannot view my previous pictures..
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Memory card trouble
The camera should have come with a USB cable with which to connect the camera straight to the computer. Connect the camera (with the memory card inserted) to the computer and see if you can access the photos.
Don't know how to set up my camera to take pictues
turn the camera on with the button on top, then take off the lens cap and insert a memory card into the side. The pictures will save to the memory card and you can buy an adapter to connect the memory card to your computer to view and save the pictures.
I use pl70. i am having problem downloading my pictures. when i connect my camera to my computer i do not see my pictures, i have even tried inserting the memory card directly to my computer and i still...
1) Using new memory card. first connecting memory card to computer and format. and insert memory card to camera. making single shot. then connecting computer you see picture.
Memory card formating in camera may be not working computer or other device.
Hello there, I have a Kodak SD card in my Samsung camera. When I have the card in the camera, I can view the pictures on the camera screen fine. However, when I insert the card into the computer, it...
If you can also view the pictures on the camera with no card inserted, it means the pictures are actually on the camera's internal memory. Try that first. Next, understand that sometimes the built-in slots on a computer can stop working for no apparent reason. Get a separate card reader and try that. typrice_104.jpg
How do i view photos on computer
All you need to have is card reader for your camera memory card.
you can upload your photos by inserting your camera memory card to a card reader (should be compatible with your memory card) connected to the computer. your pictures will be downloaded immediately, and that's it. you can now view your pictures.
2helpful
I want to know what i need to do next after i have put my sd card into my computer, a green light comes on, and i want to know how to get my pictures to come up on my computer, so i can do any adjustments...
1. When you insert a memory card into your computer, it'll be detected automatically and an "AutoPlay" dialog box will ask you to what to do ?
2. Select "Open folder to view files" option from the list.
3. Now, you can easily view the files in the memory card by double-clicking them.
4. If the "AutoPlay" dialog box doesn't appear, goto Start >> My Computer. Here you can view the memory card as a "Removable Drive" with some name!
5. Double-click the memory card's icon to view the files inside it.
6. After your job is complete, you can remove the memory card by just clicking the USB device icon at the right side of Task Bar (Notification Area)!
7. On click, a single option pop-up will appear with "Safely Remove USB Mass Storage Device" message!
8. Just click on that pop-up. A "Safe To Remove" message box will appear.
9. Click on OK button, and manually remove your memory card!
please rate this advice if it helps...tc! :)
Computer won't read memory stick
SCMG - You won't be inserting it into your modem. But if the card fits snuggly and it seems to fit right, then you're probably where you need to be.
For all of you - it may be easier to connect the camera directly to the computer to download the pictures. All cameras come with the appropriate cable to connect the camera to a USB port. All you need to do is make the connection and then put the camera into "review" mode to view the pictures and Windows should automatically see the camera and ask if you want to download the pictures off of it.
1helpful
Cannot view images on my sd card via computer
Try to remove the SD card from the camera and view the pictures. If you can still view the pictures it means that they are in the internal 8mb memory. If it is inth internal 8MB memory, you have to connect to a PC in order to transfer them.
Computers & Internet Logo
Ekse
