SOURCE: Hi, These things have
Hi The issue is with the belt that is worn out or bad and
should be replaced; if that is loose/broken will usually cause a squeaking
sound. After replacing the belt if the control panel will still not work then
check the thermal fuse located inside the back panel on the blower wheel
housing, if that is bad control will not work. If you want to do this yourself
then you can check this parts diagram. Hope this helps...please post back for
further assistance. Daniel
Hello, trgottlieb I was trying to helpyou out here. I am not sure if this well help you, but here is a link to abouteverything you want to know about your dryer, from repair to trouble shootingit. If you go to this link and click around, I am sure you will find out so muchabout your dryer, you will know more that the company that made it. Here Is thelink for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helpedyou at all, if you can find the time to rate my help and some kind wordswritten would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
the plug or the outlet is too small? There are some different styles for these, starting a handful of years ago, they are starting to use 4 prong outlets, so it may only be a simple matter of changing the outlet or the plug, depending on your choice of the two.
