My rex rx-1804 has been my pride and joy and now it seems to be a disaster. the needle is not catching the bobbin thread. i tried re-threading it, changing needles, cleaning, changing thread, thread tension and bobbin tension i even cleaned the bobbin case it self. PLEASE HELP!!! I WOULD HATE TO BUY A NEW MACHINE AND ITS A SIMPLE PROBLEM....HELP!!
Make sure that your needle is all the way up. With many needle clamps, loosening it enough to remove a needle is not enough to insert one -- you have to loosen it a little bit more. You can determine that by looking right above the clamp on the shaft -- there is what looks like a grey bar and the end of the needle should be right under it. If your needle is too low, it will not catch the thread.
Carmen, seem that you have carried out the necessary rectification, but could it be your rotary hook tip blunt/broken, if not most probably it needs needle/hook timing adjustment. And this will require your sewing machine technician to do it.
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
if you are using HUS bobbins make sure you have it in the holder with the H facing up and then wind through the 2 small pieces of metal.. Hope this helps!
