This is a tip explaining exactly what you should keep in mind when you want to upgrade your ram modules in your Desktop computer. This will also act as a guide which will give you step by step instructions on how to replace the ram module.
Firstly, before we start buying, we need to be sure that the upgraded ram modules are compatible with your motherboard. Here are a couple of tips you need to keep in mind.
Frequency:You need to have a look at the frequency of the ram you are using at the moment, as well as the supported frequency of your motherboard. If your motherboard is compatible with a higher ram frequency than your current ram, you can use the frequency which the motherboard stated as maximum for optimum performance. Remember, if yu want to add ram modules, all ram will be downgraded to the ram with the lowest frequency.
Ram model:You need to know if you are using DDR, DDR1, DDR2, DDR3 ram, some motherboards supports both DDR2 and DDR3. If your motherboard does not support a certain model, it will not fit in the slot on the motherboard, hence, it will be useless. Thus, you need to have a look at the ram model supported by your motherboard.
Latency:Lastly, you need to have a look at the latency of the ram. The lower the latency, the better the performance.
After you have bought the new upgraded ram modules, we can install them. The following steps will guide you through the installation process.
Step 1Shut down your computer and unplug all cables. Also, you need to take of the side panel of your computer. Remember to stay grounded at all times when you start working with the hardware of your computer.
Step 2The second step will be to either take out the current ram modules to upgrade them, or insert the new ram modules into the other available ram slots on the motherboard. Remember to keep yourself grounded at all times while touching the any of the computer hardware. Also, handle the ram at the length end at all times, not at the width end. There will be 2 small hinges on both sides at the base of each ram modules end. You need to pivot the outwards before the ram module can be removed or inserted.
Step 3The last step will be to screw back the side panel after you have inserted the ram modules(Be sure that you remember to clip back the hinges to ensure that the ram module is places in correctly. Never force the module, line up the ram module with the slot on the motherboard.) Also, plug back all cables into the Computer case, and enjoy your handwork.
At the links below you will be able to have a look at sme competative prices on ram modules.
http://www.crucial.com/http://www.kingston.com/ukroot/http://www.upgradecomputermemory.com/http://www.memory-up.com/Memory/GatewayPerformance.html?gclid=CJesovOPiaACFaFi4wodjBrVkQPlease let me know if you have found this to be helpful.
Kind regards
Andrea
