Logitech X-240 Computer Speakers Logo
Posted on Aug 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I turned on the power for my 'Logitech X-240' speakers, there was a loud static noise coming from the speakers. I unplugged the speakers from the subwoofer, and as I began to plug them back in, the static returned. The noise is there regardless of the volume level. Any help would be appreciated
Brian Sullivan
Level 3:
  • Logitech Master 27,725 Answers
  • Posted on Aug 31, 2011
Brian Sullivan
Logitech Master
Level 3:
Answers
27725
Questions
Helped
5664181
Points
79191
Clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Loud speaker static when the car is off. It drained that battery. I tried pulling the radio fuse but it was still making the noise. I had to disconnect the battery to get it to stop. Any ideas?
I GUESS that the speakers are driven by an after market amplifier. An amplifier needs to be connected to a power source that is only on when the radio is on, through a relay.
So I GUESS that:
  1. The wiring is incorrect. Or
  2. If is has a relay, the relay is stuck.
When I plug in my speakers, they make a constant static sound. It can become quite loud at times and I've found that turning the input chord around can sometimes work, or unplugging the charger for my...
if your speakers are near to some electronic devices you'll get theses static noises try to keep them away from electronic devices which solves it very easily..
Logitech speakers occasionally making loud thudding noise!?
i have the same problem.... its very annoying, i cant get it to go away!
Humming Noise from satellite speakers
noise can be generated since dust in the jack connector of your PC, bad sound card or belive or not, the socket. try to unplug another devices and leave alone the x240... compare.
Logitech x-240 speakers
Try to unplug everything, re-install drivers and see what happens.
Logitech X-240 Speaker Volume Problem!?!?
you probably have it plugged into the wrong jack
They Crashed
seem static electricty issue.
unplug computer from the wall socket and hold down the power botton for 10 sec. do the same with speakers. pluge back it should work.
hope it will help..
Top Logitech Audio Players & Recorders Experts
Paul Bade
 Grubhead
Grubhead
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
