Question about Sharp Aquos LC-45GD6U 45 in. LCD HDTV
In moving have lost power cord to my Sharp model LC 45GDu6 tv. Where can I get a replacement and what specs do I need to make sure I get. Thanks for your help
Posted by anw53 on
Lawrence Oravetz
  • Sharp Master
  • 10,548 Answers
The power cord is the same as the ones used on desk top computers . Any store that sells computer parts will have it.
Posted on Dec 31, 2014
5 Related Answers
Anonymous
  • 14 Answers
SOURCE: sharp aquos lc -32da5u
Probably needs a new main unit or power supply board replaced. Most times is main unit
Posted on Jul 25, 2008
Jon Hill
  • 49 Answers
SOURCE: Show Microsoft Power point on Sharp Aquos hdtv
try to right click the desktop and choose graphics options, you will have to select the correct output for your setup. i.e. laptop to monitor, etc etc see if that works,...sounds like you have a connection, you will have to play with these settings until it pops up. worked with a similar scenario, sometimes you have to do stufff twice and it works on the second time not the first, electronics are weird.
keep changing the settings in the graphics options until it comes up the way you want it.
Posted on Nov 13, 2008
Anonymous
SOURCE: remote control tv codes for sharp lc-32sb24u tv
I need the remote codes for sharp LC-32SB24U tv. Thank you!
Posted on Nov 23, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
Anonymous
  • 124 Answers
SOURCE: Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
ps3 signal is 1080p you need a 1080p tv for it to be compatible.
Posted on Sep 17, 2009
Testimonial: "Thanks"
C3742U. Where can I get a replacement power cord?
If you mean the Sharp LC-C3742U TV, the power cord is part number: QACCDA039WJPZ . Several vendors have the power cord, including Amazon.com. See http://www.amazon.com/SHARP-OEM-QACCDA039WJPZ-CORD-CORE/dp/B001DEJTN6 and https://www.partstore.com/Part/Sharp/Sharp/LCC3742U/Sharp/Sharp/QACCDA039WJPZ/New.aspx, among other links.
I hope this helps.
Dec 18, 2015 | Sharp Aquos LC-13B6U-S LCD flat panel TV...
I need to find a sharp lcd tv model lc-32a33m power cord. Where can I get one?
Jus guessing but is it really different form other power cords? You should look at any electric parts store orat some home depot.
Check also at Sears;
SharpTelevision Parts
Sharp Television Parts and Accessories
Sharp TV Parts eBay
Aug 27, 2015 | Sharp Televison & Video
I removed my Tv stand to my Sharp LC-C4254U tv to install it on the wall now i need to use the tv stand again because i moved and I missplaced the screws for the stand so I need to know the sizes of the...
You need to call your dealer or customer service for the replacement of lost screws.
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Nov 01, 2010 | Sharp LC-C4254U 42 in. LCD TV
I was playing Playstation on it and it lost power.
Unplug the tv about an hour,replug it back in should reset it self and work.Not, the power supply board it dead,that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 12, 2010 | Sharp LC-32SH12U TV
I LOST MY POWER INPUT CORD FOR LC-225VTU
Tries Partstore.com,if out of stock,buy it on Ebay.com or Amazon.com plug use in playstation 1,2 use the same plug.
Nov 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Missing Power cord for a 52" TV Aquos, What do I need to order?
you can use the noraml power cord which is used for the desktop computers power cable you can get in the computer accessories shop.the power cable which connects the tower cpu fits your LCD tv too.
Oct 20, 2009 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
Can't Find the Operation Manual for Sharp LCD TV Model LC-32D47U
Try to download the manual from this link if your LCD is the LC-32SB23U.
Sep 19, 2009 | Sharp LC-32SB23U 32 in. LCD TV
Open Questions:
Sharp Aquos LC-45GD6U 45 in. LCD HDTV Logo
Top Sharp Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
