Question about Curtis LCD2424A 24 in. LCD HDTV
I have a curtis tv model LCD2425A it was working ok untill today .MY tv is connected to dishnetwork my tv says scan channels did this still can't get any thing had this tv about 3or 4 months.tried connecting another tv to the same cable this tv was connected to that tv worked ok
Posted by Jadette Spradley... on
Chi Chu
  • Curtis Master
  • 8,457 Answers
The tv only 3 or 4 months olds take the tv warrenty repair or return it were u bought it trade it in for another new tv.This tv the main tv Tuner signal itself have problems,if after scanning channels and come up with nothing.
Posted on Aug 31, 2011
Direct tv remote rc65/lcd2425a Curtis tv code
I was about to give up and the last thing I tred worked as a full remote.
Use any cell phone I have android. Download free Peel Smart Remote. When setting up remote choose Sony. Works like a charm.
Oct 22, 2013 | Curtis LCD2425A TV
No picture but have sound
Check the cable connections that you have. Try a different channel or make sure that its on the right input or source. Make sure cables are firmly connected. Try to switch it to ATV mode.
Sep 20, 2013 | Curtis LCD2425A TV
Unlock Curtis lcd2425a
got the original remote? GOT a box or not?
May 14, 2012 | Curtis LCD2425A TV
MY CHANNELS DO NOT APPEAR WHEN I USE AUTO SCANN ON A CURTIS TV MODEL LCD2425A
Try to direct enter a channel with the number buttons on the remote--if that works you can then in the menu "ADD" it to the set's memory--time consuming but may work.
If no luck let me know: using box? Connected to coax fitting? Rear audio and video jacks are working?
May 02, 2012 | Televison & Video
Code fro lcd2425a curtis mathes television
Hi
Setup code for Curits Mathes Tv with RCA RCR 311B unversal remote control is,
1078
OK.
Jul 14, 2011 | Curtis-Mathis CM32010 TV
I just hooked up my Curtis lcd2425a tv and get no picture or sound. Just a white screen.
It might be the cable not the tv... Try hooking up an xbox or ps3... If the picture comes up on that then have someone come over to your house to fix the cable... If it doesn't work then send in your tv for a new one... Best if luck
Apr 02, 2011 | Curtis LCD2425A TV
I need comcast remote codes for a curtis lcd2425a
Code 10000 is what WORKED for my Comcast DTA remote on my Curtis LCD2425A! Another poster suggested using Sony codes and that was the first one on the list. Wahoo!
Mar 13, 2011 | Televison & Video
Can set up th remote control for this tv with the direct tv cable remote
Here's how to scan for TV codes on your DIRECTV remote
1.Make sure your TV is turned on.
2.Slide the mode switch at top of remote to "TV".
3.Press and hold the MUTE button. This is located above the number 1 button.
4.While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
5.Then enter 991, the green light on remote should flash twice.
5b. Press 1 again (it will flash twice again), then you press the power on button at the very top right.
6.Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
*If you hit channel up very fast, you risk going past the code. Pressing channel down will back it up. I alway hit channel up very fast till the tv turns off, then back it up slowly till it comes back on.
7.When the TV powers off, press and release the SELECT button.
*Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
Mar 05, 2011 | Curtis LCD2425A TV
I have a CURTIS LCD2425A TV and I am looking for the TV code to enter into my Panasonic remote.
You can go online and google the panasonic remote code list, make sure you put in the model number under the panasonic remote
Dec 28, 2010 | Curtis LCDVD2454A TV
Curtis LCD2424A 24 in. LCD HDTV Logo
Top Curtis Televison & Video Experts
Abhinandan  Patil
Abhinandan Patil
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
