An E3 error code in a Canon MP210 printer is frustrating. This code reflects a paper jam that is not always apparent immediately and can be indicative of other problems.
Remove the jammed paper by pulling it from the front or top of the printer. If it does not come out, restart the printer to eject the paper. If the paper fails to come out or rips, remove the cover and retry. Once you have removed all visible paper, check paper sensor paths for debris or damage, blowing it out as needed.
Reload the paper as recommended and print a test page using the printer's software. If the error continues, the sensor that generates the error may be damaged. If so, take your printer to an authorized service center.
Follow this instruction step by step.
1. Turn Off
printer, cable power still plug in.
2. Press
Stop/Reset button, don't release the button.
3. Press Power
button by holding without release and than release Stop/Reset Button.
4. Press
Stop/Reset button two times (2x) now release the Power Button.
5. Wait until
service mode to zero (0).
6. Turn off
the Printer, cable power still plug in.
7. Press
Stop/Reset button, don't release it.
8. Press Power
button don't release & than release Stop/Release button.
9. Press
Stop/Reset button four times (4x), wait until service mode to "1"
10. Turn off
printer, and loose cable power, wait for one (1) minute.
11. Connect cable power, turn on printer again, now this printer ready to use.
1. Turn Off
2. Press
3. Press Power
4. Press
5. Wait until
6. Turn off
7. Press
8. Press Power
9. Press
10. Turn off
