Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
Posted on Aug 31, 2011
I need software for motorola mts 2000 flashport
Eric Schaefer
Level 1:
  • Contributor 44 Answers
  • Posted on Jan 31, 2014
 Eric Schaefer
Contributor
Level 1:
Answers
44
Questions
Helped
14040
Points
55
You would need a programming cable as well. This is more likely than not beyond your current level of skill. This software is licensed by Moto, complex and not easy to get over the web. I suggest that first you sit down and make an outline of exactly what frequencies you want to transmit on if you are licensed and what to scan etc and go to a radio shop. It will be worth the money.
2 Related Answers
Anonymous
  • 56 Answers
  • Posted on Feb 12, 2010
SOURCE: what are the button functions?
The buttons are programmable through the Radio Service Software (RSS) and can be used for any number of features. Some examples are Monitor, Scan, Repeater Access Tone (RAT), Light, Select, and the list goes on. Only reading the radio with the RSS can you be 100% sure.
A wealth of knowledge can be found at http://www.batlabs.com/mtsx.html as well as searching the forum located there.
Testimonial: "the orange button is the panic button. the green button on the side is the back light...the rest I will leave alone."
Anonymous
  • 56 Answers
SOURCE: how do i program my motorola mts 2000 flashport
Your Motorola MTS2000 is not a scanner but a high-end two-way radio. It requires a computer, special interface box (called a RIB, for Radio Interface Box), the proper cable from the radio to the RIB, and the programming software called RSS (Radio Service Software.)
This is much more difficult than a scanner to program and if not done properly can cause the radio to automatically transmit on frequencies that you are not authorized to use.
Try calling your local Motorola dealer and ask them if they will program it for you for receiving only. They will either flatly refuse or they will be happy to charge you a service fee. Some places are more willing than others.
I need to know the channel my motorola mts2000 flashport is operating on
This type of radio can only be read out by someone with a software subscription and appropriate equipment. This could be an online or local Motorola dealer, a large company, or a municipality.
Best regards.
Trying to get an MTS 2000 FLASHPORT to ride a primary channel and scan another channel
Program the scan list in the codeplug. This is a feature that must be programmed into the radio via the dealer programming software. By using the software the dealer will program scanning capabilities and then assign a button on the control head to turn scanning on and off. Every radio can have different features and functions programmed into the radio. If by pressing buttons on the face a "Z" like symbol apears, you've found your scan on/off button.
2helpful
What are the button functions?
1helpful
Motorola MTS 2000
Motorola may be able to tell you if you call them, but they may refuse.
If your radio has a front display, you can put it into test mode to see what firmware it has. If it is 5.44 or higher, then it is FlashPort.
You access the service menu by pushing the button with two dots (on the side above the PTT) 5 times quickly after the power-up beep. If you have no front display this is useless.
1helpful
2answers
How do i program my motorola mts 2000 flashport scanner
Motorola mts 2000
MTS2000 software will operate on Win98 and possibly XP, depending on the revision number you have. Yes, you can clone if the model number is the same. It will clone the entire codeplug of the radio. (Note: you will not have 2 same serial numbers. These are unique to the individual radio.)
How to prograqm a motorola mts 2000 flashport?
1. Program the ABC switch as zone select.
2. Program each 'personality' into the proper zone (eg A1, A2..., B1, B2..., C1, C2..., etc)
3. Load the codeplug into the radio.
Programming
Why buy a radio you cant program? I suggest you google for Motorola authorized radio shops in your area. Unless you have the software and equipment to do it, you won't be able to. You will also need letters of authorization for any channels you wish to have programed for transmit. If your a HAM or GMRS user be sure to bring a copy of your licence.
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
