Question about Dryers
The dryer works fine if I could push the start button. The dot is caved in behind the start button and you can't get the dryer to start any other way. Can I open up the circuit board and flip it upside down behind front board and the top right -start button could become the bottom left? only the little tab is not working behind the start button. Board model DPXB515
    Top Expert:
  • Dryers Master
  • 9,472 Answers
You will need to replace the interface board. Here is a link to the part you need.
Posted on Aug 31, 2011
When I push the start button, why doesn't it start?
If it has been working fine, Check the switch behind the door. There is a safety switch, so it will not start if door is open. If no sound then it may be the safety switch. God-Bless!
Jan 23, 2016 | EuroTech EDC158 Electric Dryer
I push start button and it humm's and dosen't spin i open the top of the dryer and then push the start button and the push the drum to jump spin it and then it work's.any thought's
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 05, 2011 | Dryers
My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Fisher Paykel Dryer Model DE08-US1. Dryer won't start. When pushing the start button, there is a "humm" from the electric motor - like it's trying to start. Very sudden problem. ...
heatman101
Jul 18, 2011 | Fisher and Paykel DEGX1 Electric Dryer
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
Kenmore 90 series dryer. Was working fine three days ago, now it won't start when you set the timer and push the button to start. Is ther a reset button or something? Checked breaker at electric panel...
heatman101
Jun 30, 2011 | Kenmore Dryers
Dryer will not start when On button is pushed to start.
Check out the door switch. Push it in as far as you can by hand and hold then hhave someone try and start it. If that works you need a new door switch
Jun 10, 2010 | Crosley CDE6000 Electric Dryer
Maytag Dryer Has No Power
i am sorry to hear this, mdg model number means that you have a gas dryer, you have a fuse and thermastat that needs to be replaced which is beneath the top behind the drum, you will see a short element, a blue thermastat and 2 white wires that goes down to a fuse.
when you buy the fuse, it comes as a kit, the thermastat and 2 fuses, one of the small fuses you will not use because one if for an electric dryer, so look at your fuse and notice a dot, i do believe your dot will be yellow...
so lift up the top and you will see these parts
Aug 23, 2009 | Whirlpool LGB6300 Gas Dryer
Dryers Logo
54 people viewed this question
Top Dryers Experts
Marvin
Marvin
Mike
