SOURCE: indesit D63
It sound that the problem is cause the water level switch (stuck in the "full" water position). The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you will find it easily. Clear first any obstruction in the tube,In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it doesn't react, you should replace it. Good luck !
SOURCE: Leaking Indesit D63 dishwasher
try pushing down firmly on inner door panel at the bottom with door fully open. You will feel it starting to bend. This moves seal closer together when door shut. it worked well for mine.
SOURCE: Replacing a DoOr Seal
as i remember it, you will have to take off the door front panel and slot in the seal from inside of the lower door. if im thinking of the wrong model and the advise is wrong i will get back to ya.
SOURCE: indesit D63 dishwasher dishes not getting clean
Check the rinse aid dispenser is set properly to release a small amount of rinse aid not full and not off but the first click should be fine,then under the bottom rack there are filters remove then and clean them regular,also remember to wash the dishes the same night that you use them ,leaving them over nite will result in the food going hard and you will need a hammer and chizel to remove some dried food,last please remember this is a dishwasher not a food disposal unit you need to rinse the dishes and scrap off loose food before washing
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
34fes
