SOURCE: LG CE 0168 phone security code Lock
have you left the phone off for 24 hours if you switch it on and it is asking for security code i can get the master override code for your phone but i need the imei number and the code number off the back of your phone under battery the imei is 15 or 16 numbers long might be like123456/44/22343/2 and then the other one is about 6 numbers long 123456 if you give me these i can give you master code if your phone dont ask for code then you need to get it flashed at a shop to unlock it hope this is some help
SOURCE: i need a security code for my LG CU500, it locked me out:(
hi there
have you tried the default security code? its 0000. if it still wont work, you can try 277634#*# and do a factory reset from this menu.
hope this helps
SOURCE: forgot security password
hi,
Use 277634#*# it will open a hidden engineer menu and use the reset phone option it will set all settings on phone to default including security code back to 0000
SOURCE: Reset password for a lg env3 phone
i cant get in my phone when i turn it on i forgot the password
