Question about Texas Instruments TI-89 Calculator
Solve() gives me wrong answer. -20^2=12^2+2X(-5-3). The answer is -16, But my TI-89 is giving me 34 during the solve funtion. my TI-83 is also giving me -20^2=-400 not 400.
Posted by mpelsh on
Stevan Milanovic
    Sergeant:
  • Texas Instru... Expert
  • 267 Answers
For the first problem you have to type: solve(-20^2=12^2+(2*X*(-5-3)),x)
Also, make sure you use the (-) key on the position number 5, just to the right of the decimal point and not the - key and on the number 3 you have type regulary subtraction - key
Answered: Stevan Milanovic
Posted on Nov 06, 2011
  • 1 more comment
  • Stevan Milanovic Nov 06, 2011
    For the first problem you have to type: solve((-20)^2=12^2+(2*X*(-5-3)),x)
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Enter the first term as (-20^2), not as -20^2. Without the parentheses the calculator interprets it as
-(20^2), which is not what you want.
Also, make sure you use the (-) key just to the right of the decimal point and not the - key.
Posted on Aug 31, 2011
Logbase16xtopower5=logbase64 125-logbase4rootx soveforx
Type solve(log(x^5,16)-log(125,64)+log(x^(1/2),4),x,0.5
Its equation with guess 0,5. Then press enter and you will give result
x=5^(1/3)=1.70997
Or, you can use equation solver with eqn=0(MATH, then B option)
See captured images below
Feb 26, 2013 | Texas Instruments TI-83 Plus Calculator
My Ti-89 is not giving the right answer for cosine. I typed in the cos(42) and it gave me -.39985 when it is supposed to be posotive .74314. Does anyone know what is wrong?
Nothing's wrong, your calculator is giving you the cosine of 42 radians. If you want the cosine of 42 degrees (which is 0.74314), press MODE, down-arrow to the "Angle" line, press right-arrow, select "2:DEGREE", and press ENTER twice.
Dec 13, 2012 | Texas Instruments TI-89 Calculator
My ti-83 plus is giving me the wrong answer only when i divide.
I am sorry, there is nothing to fix. The answer is perfectly correct. 62250/1450=439310344828
I think you meant to divide 65250 by 1450, the result of which is 45.
Jun 29, 2012 | Texas Instruments TI-83 Plus Calculator
My TI-83 plus seems to give me the wrong answer if I type in the problem: 1400/(60*24) The answer should be 1, but I keep getting .9722222. I don't understand why it keeps giving me the wrong...
That is the correct answer. 60 multiplied by 24 is 1440. 1400 divided by 1440 is a number slightly smaller than 1.
Are you sure the problem isn't 1440/(60*24)?
Jun 22, 2011 | Texas Instruments TI-83 Plus Calculator
TI89 is giving wrong answer for the integral of sec(x). Please help. It gives the answer as: ln[ |cos(x) / (sin(x)-1)| ] when it should be ln[ |(sin(x)-1) / cos(x)| ]. Why is it giving the wrong...
Hi danagasta,
If my last instructions did not work then you need to reset your RAM. You are missing the negative sign and, I have no idea where you got the absolute value inside the brackets.
Yes, the absolute value are used in books and, on integral tables but, I can asure you that the Ti 89 should not have produce them in this answer.
I'll stand behind that In( -cos(x) / (sin(x)-1)) is the correct answer. You can go ahead and simplify after the calculation to get the answer you want but, that is the good answer that Ti 89 is going to give you for the integral of sec(x).
Errors that do not match the suspected, I am pretty sure that Texas Instruments would have you clear the RAM. I do not like resetting the RAM but, I could not find the cause to why you got the answer you did. And so far no other expert has produced a solution to convince me otherwise.
I was not able to come up with any of the 3 answers MiB8888 did on my Ti 89. I am not saying that they are not good answers, they are book and integral tables answers. You are not going to get them on the Ti 89.
Jan 04, 2011 | Texas Instruments TI-89 Calculator
I ask my TI-83 Plus to calculate (-64)^(3/2) The TI-83 Plus says the answer is -512i, but I think the answer should be 512i. Is the calculator wrong or am I?
You're both right, in a way. (-64)^3 is -262144. The square root of that is +/- 512i. Take your choice as to the sign.
For what it's worth, the TI-84, TI-86, TI-89, and the HP 50g all go with the negative value.
Jan 24, 2010 | Texas Instruments TI-83 Plus Calculator
I received this solution, but at the end the calculator asked me about some invalid certificate. Now the ti 89 is stuck at the boot screen because if I retry, it goes thru the whole process again and asks...
The answer I gave you was taken verbatim from the TI FAQ and knowledge base. I copied and pasted the part relevant to you calculator.
In any case, I sent an e-mail message to [email protected], giving the link to your original question and my answer to it. I took the liberty to copy/paste your present message. I also asked about that invalid certificate.
All we can do know is wait for their reply.
k24674.
Oct 31, 2009 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
216 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
