Question about Northstar Generator 9 Hp, 5500 Watt, Gasoline
Generator runs fine- does not produce any power- checked breakers all ok
Posted by ronsantor on
Starlight Power
    Sergeant:
  • 117 Answers
If your generator produces no electricity or power, you can check the following causes:
1. The residual magnetism of the generator core is disappeared or too weak.
The residual magnetism can be lost naturally when the genset is placed too long or it can also happen from running a generator with no load for too long. However, for the new genset, the residual magnetism can be lost due to a long distance transportation vibration. Thus, it will cause the remanence voltage of generator is disappeared or less than normal remanence voltage value, namely, the remanence line voltage is less than 10V, the remanence phase voltage is less than 6V. Because the stator of synchronous generator, rotor, as well as AC exciter stator, and rotor core are usually folded by adopting 1~1.5mm thick silicon steel sheet. After excitation vibration, the residual magnetism is easy to disappear or weaken. When the residual magnetism is lost, the generator will produce no power at start-up.
2. Excitation circuit wiring error
The polarity of the excitation winding is reversed. After electrifying, the magnetic field produced by the field winding current is counteracted with the residual magnetism, resulting in the disappearance of the remanence. In addition, when measuring the DC resistance of the excitation winding or testing the automatic voltage regulator AVR, without paying attention to the polarity, which will also cause the core remanence to disappear.
3. Excitation circuit is blocked
In the generator excitation circuit, the electrical contact is bad or the wiring head of each electrical component is loose, the lead wire is broken, causing the circuit to be interrupted, and the generator excitation winding has no excitation current.
4. Circuit for DC side of rotary rectifier is interrupted
Due to the interruption of circuit for DC side of rotary rectifier, therefore, after the AC exciter is rectified by the rotary rectifier, the excitation current supplied to the excitation winding can not be sent into the excitation winding, resulting in AC synchronous generator can not generate electricity.
5. AC exciter fault, no output voltage
The generator can't produce electricity due to AC exciter failure, so that the excitation winding of the AC synchronous generator has no excitation current.
6. Generator excitation winding is broken or grounded, resulting in the generator has no excitation current or the excitation current is minimal.
Helpful article: https://www.dieselgeneratortech.com/generators/why-generator-wont-produce-electricity.html
Posted on Jan 06, 2020
Richard Morris
    Master:
  • 577 Answers
The voltage regulator for the generator is not work, replace it. Why, if there no dc voltage to excite the stator it won't any output. GB...stewbison
Posted on Aug 31, 2011
1 Related Answer
Anonymous
  • 205 Answers
SOURCE: have a gg3500 gas generator that give no current
you need to check to make sure you have no power out put, check all receptacle. if none check your owner Manuel on how to flash your unit. you may want to check all breakers. if flashing don't work take it to repair center to check stator and rotor
Posted on Oct 13, 2009
Husky 5000 watt generator quit producing power.
You could have a bad circuit breaker button. Replace that and see what happens.
Dec 24, 2015 | Husky Electrical Supplies
Portable generator head stopped making power
portable generator head stoped making power engine runs fine sircut brakers are fine
Mar 16, 2010 | Pramac Electrical Supplies
My generator is not producing power runs fine does not make power
Could be several problems on the gen set itself. Check to see if there is a surge protection breaker or fuse, depending on age. Make sure all connecting wires are secure and switches are not set to 240v instead of 120v if you are trying to use outlets.
Jan 04, 2010 | Coleman Powermate Powermate 5000W...
Generator runs, but produces no power
If it's still under warranty take it back to the retailer and tell them it quit working - don't offer any other information.
If you must fix the E/G yourself - On the generator there's a cover on the back; take the cover off so that the back of the windings are exposed. You should see 4 to 6 diodes mounted to the rotor and stator...those diodes are most likely burned out because of temperature failure, due to overload. You have to take them out to isolate them...they should read .6 Ohms one way; reverse the leads and they slhould read about 1.2 Ohms. If there shorted you'll read 0 Ohms and open infinety.
Anyway, replace those diodes and you should re-establish your field winding voltage which develops you A/C output.
Good Luck,
Mike...
Nov 22, 2009 | Coleman Powermate Proforce 2500 Generator
Have a gg3500 gas generator that give no current
Oct 03, 2009 | Electrical Supplies
Generator rus fine but does not produce power
check the brushes at the armature,armature should be shiney,if not take emory cloth and clean the armature,see if that helps.
Jul 06, 2009 | Hobart Welders Champion 500433A Factory...
No output from my generator
check breaker, your outlets should be like a gfi
May 21, 2009 | Coleman Powermate Premium Plus 6250W...
Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
Mar 24, 2009 | Yamaha 4500 Watt Electric Start Generator...
Generator runs producing no power
Hi, remove the electric control panel & check the wiring as sometimes we have seen the wires coming off the voltage change over switches.
Also some of these units you can check the connections in the rear of the alternator & if it has brushes that they are not stuck.
Another problem we have had is the trip switches have went faulty but still switch operates ok, they need to be checked with a probe type tester for conductivety.
Nov 01, 2008 | Porter Cable 5,500 Watt Portable Generator...
Northstar Generator 9 Hp, 5500 Watt, Gasoline Logo
1,244 people viewed this question
Top Northstar Electrical Supplies Experts
Sheldon Dedek
john h
Marvin
Marvin
Are you a Northstar Electrical Supply Expert? Answer questions, earn points and help others
