Question about Kenmore Elite TRIO® 7854 (25 cu ft) Bottom Freezer French Door Refrigerator
I have a 2006 kenmore elite trio refridgerator wirh french doors and bottom freezer. on of the door handles is loose. what tool do i use to tighten handle. each handle has a screw at top and bottom. The screw seems to set deep in hole and hole is threaded. Please help me.
Posted by lorrainegjoh on
Richard Morris
    Master:
  • 577 Answers
There is two allen set screws for each hand at both end and they are facing each other on the handles.. Remove the allen screw and put a very minute speck of jelly on each screw---small-small amount. This will kept the set screws from loosen up. GB...stewbison
Posted on Aug 31, 2011
How do I take KENMORE ELITE TRIO 596.75533400 out of demo mode?
Try pressing ultra ice and home while the refrigerator door is opened,or ultra ice and the refrigerator pad with the freezer opened. Hold for five seconds. Hope that works.
Jun 12, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
Our Kenmore Elite french door bottom freezer, automatic icemaker, no water/ice dispenser on the door - is leaking quite a bit - had to mop up the floor three times today. first time it's happened since...
Check for cracks in the water supply tube from the house plumbing valve to the ice maker. Could also be the valve itself.
Turn off valve for a day to diagnose which.
Oct 21, 2017 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
No water or ice or lights on outside of door
I received my Elite TRIO 795.7101 2 weeks ago. I have ran over 3 gallons of water though it. I am still getting a bad odor and taste when I dispenser water from the door.
Nov 03, 2010 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Kenmore/Elite Model 795.7756,7757 Trio: Bottom Freezer Door won't close. The latch or hook at the bottom corner of each side will not hook in.
We have a kenmore elite refrigerator modle number- 795 7756,7757 and it has been making a humming noise very constant now after two weeks, what could it be?
Sep 18, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
How to remove freezer door handle
There should be one or more hex shaped keys within the door handle, usually on the side or bottom of the handle. Simply loosen them up and the handle should pop right off.
Jun 14, 2010 | Kenmore 24.8 cu. ft. Trio French Door...
My Kenmore Elite french doors bottom freezer drawer fridge has condinsation in the top of my fridge what is causing this?
bad/dirty door seals allowing fresh moist air in.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 24, 2009 | Kenmore 24.8 cu. ft. Trio French Door...
Sears trio elite ...french doors with bottom freezer...right side loose on freezer door handle...thanks
I have the same refrig. After taking the freezer basket hinges off, thinking I had to take the whole door a part to access the screws for the handle...my husband figured that the handle probably slides off...and yes that is just what it does!
Push the handle in a bit and then slide to the right. It takes a little bit of effort but that handle will come right off. Then you can tighten the screw that holds the clip in place. Then you line the handle back up to the clips, and slide to the left. Good Luck!
Apr 08, 2009 | Kenmore Refrigerators
Loose handle on door
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Bottom Freezer door handle
I had the same problem. It took me an hour to figure out that the bottom freezer handles clips onto the door using butterfly clips. To tighten the clips you have to remove the handle by sliding it to the right (or left??) It snaps right out with a quick **** exposing the clips underneath. A quick tightening of the clips and the handle snaps back in.
Nov 07, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite TRIO® 7854 (25 cu ft) Bottom Freezer French Door Refrigerator Logo
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
