2003 Lincoln Navigator Logo
Posted on Sep 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lincoln Navigator Dvd player will not read the Dvds
Factory installed DVD player will not read the dvds. Screen will stay blue. System will show a dvd if I attach an external dvd player to the screen.
  • Anonymous Dec 19, 2008
    I tried an expensive cleaning disc with 10 brushes. The first time I tried it was yesterday after I purchased it. It read thre disc and went through several checks.I then put a disc in and it ejected it. So I put the cleaning disc back in and it wouldn;t accept it.
Anonymous
Level 3:
President:
  • Master 1,450 Answers
  • Posted on Sep 10, 2008
Anonymous
Master
Level 3:
President:
Answers
1450
Questions
Helped
797036
Points
4747
Try cleaning the unit with a disc cleaner.and make sure all dvds are clean
1helpful
My 2004 Lincoln Navigator has a DVD player near the passenger side but It doesn't have a monitor. What is the DVD player for.?
Is the DVD slot in the dash board or in the second row? Does it appear to be factory installed or possibly aftermarket? If factory and in the front, I'd suspect it's for loading navigation system updates. Does your Navigator have factory navigation?
-Rod
My rear DVD player in my 2010 F-Expd was working but then we changed the disc and it made a weird clicking sound like it was trying to read and gave a load disk error. It does this w/every disc.ideas?
Hello Ammie Gordon,
If you have this same response from a couple of DIFFERENT DVDs (combined with your "noise" symptom) then it is safe to assume you are having a head/drive issues ...
These units are quite robust, cleanable and serviceable... but my best ADVICE is they are also fairly INEXPENSIVE (not cheap) and available (on eBay as well (in colors)... ADDITIONALLY... identical unit were equipped in the 2010 Lincoln Navigator.
I would get a COMPLETE REPLACEMENT and have the SALAMI removed by your ORIGINAL by your favorite uncle in your leisure time...
Hurry... BLUETOOTH "PLAYLISTS" and streaming media are right behind this technology... and ...
these will be as hard to find as 8 TRACK tape players
(I'm just saying).
Hope this helps.
Expedition:
71results for 2010 ford expedition rear dvd
Navigator
60results for 2010 Lincoln navigator rear dvd
The foron screen dont show dvd - only show a blue screen. It seem to a conflict in the system as it react very slow Is it possibel to reset the system?
HELP! DVD player/video mode blue screen ONLY! - DVD Talk Forum
forum.dvdtalk.com > DVD Discussions > DVD & Home Theater Gear
Jul 26, 2005 - Windowless vans do NOT have candy, only. When I click on the set up menu, all I see is that blue screen and the green VIDEO in the ...Missing: foron
Help please--DVD/VCR combo blue screen - The Mac Resource Page
forums.macresource.com/read.php?1,653657
Jan 23, 2009 - 19 posts - ‎4 authors
I hope this does not mean that the video channel on the player is ... TV and see where you have the inputs from the DVD/VCR plugged in, if you don't know. .... viewing andonly turn on the JVC when I want to use it for a movie.Missing: foron
Sky HD box just showing blue screen...?! ' AVForums
www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
Overhead DVD player in 2008 Toyota Sienna does not show the picture. Sound works.
Hello, I hope this helps. If no change then you probably have a hardware/ wiring issue and the dvd player may need to come out. Please advise
1. Confirm the DVD RSE system is inoperative. (blank screen) 2. For vehicles with Toyota navigation system: Perform the following procedure to turn OFF the RSE Lock function. A. Press the INFO switch on the navigation unit. B. Press the "Screen Setting" touch button on the navigation display. C. Under the "Rear Lock" option, press the "OFF" touch button and then press "OK" in the upper right part of the display. D. Press the DVD switch on the RSE system (if a DVD is NOT already in the player, insert one) and confirm screen is ON and the system will play DVDs. 3. For vehicles without Toyota navigation system: Perform the following procedure to turn OFF the RSE Lock function. A. Push the Audio Control knob multiple times to cycle through the various options (Bass, Mid, Treble, etc.) until "REAR LOCK" is shown on the screen. B. Turn the Audio Control knob so the display says "OFF" next to "REAR LOCK". C. Press the DVD switch on the RSE (if a DVD is NOT already in the player, insert one) and confirm screen is ON and the system will play DVDs. 4. If the above procedure resolves the concern, explain the system operation to the customer.This procedure is described in the Audio/Video" section of the vehicle Owner's Manual. 5. If the above procedure does NOT resolve the concern, perform RSE diagnosis using the Technical Information System (TIS), 2006 model year applicable vehicle Repair Manual.
What does "NO REMOTE DVD" mean on the entertainment system screen?
Either the power to the DVD unit is off for some reason or the signal connection to the entertainment unit is loose. It sounds more like a power issue, since the ent. unit senses the DVD but can't access it. Have the dealer check it out.
Need a easy fix to play DVDs while traveling on a 2009 f150 king ranch with Sony factory system touch screen
I used to use DVD's but then I got a wireless with a usb port. I down loaded the music from my DVD's and have over 15 hours of music without hearing the same song twice. easy fix with no dvd player problems
How can I play all DVDs on the DVD player?
The DVD player maybe locked to a region, to make the player regionless so it can play DVDs from any region the player need the firmware changed.
But if you make a mistake then the player will be a piece of junk.
These WEB sites shows how to Unlock DVD Players - Region Free Code
www.dvdexploder.com/www.download-info.com/dvd/index_new.htm
1helpful
2answers
Wiring Diagram for 2003 Lincoln Navigator DVD Player
my tv screen and dvd player wont come on on my 2003 navi.
1helpful
5answers
Lincoln navigation dvd
On my '06 Navigator the navigation dvd goes in a slot on the console to the left of the passenger's feet. There's a removable panel.
On a side note... does anyone have a newer dvd for Canada? The one that came with my vehicle is compile for the Quebec (*gasp*) market and is outdated.
Top Lincoln Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
