This click noise was it coming from inside the hard drive or was it power data click
this melted lead will cause you problems it needs to be replaced
replace that lead and check all other leads from motherboard to hard drive mke sure connections are clean and secure also make sure your ram modules and cmos battery are clean with secure seatings if the lead melted must be getting hot
blow all dust from your computer you could use a fine air blower making absolutely sure there is no moisture in the air lines
if you need more help with this post a reply
hope this helps you
Better to replaced the hard drive, co'z once you heard a loud sound on it, that means that the drive is now having a physical damage, if you the hard drive still working, it will not stay longer due to physical damage inside of the hard drive.
