Question about Nokia E51 Smartphone
My nokia e51 hang up yesterday...i removed the battery and when i torn it on only notification light there is no display.....pls help me...
Posted by dondie_1106 on
Servando Nadayag
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 105 Answers
Hi and good day! will the problem of your phone is corrupted,and to solve it, reformat the phone or restore it into factory default, now after the reformat 's done please use the external memory of your phone and if possible only the contact number should be in your internal memory to avoid more problem later......
Posted on Aug 30, 2011
Sir how do I unlock my nokia e51
Hello. You can unlock your Nokia E51 safer and easier using unlock code, You can get the accurate unlock code for a Nokia E51 from ProUnlocking.com at affordable cost with an easy unlocking guide. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia E51 without any sim card.
2 - Don't bother as to what is displayed on your Nokia E51.
3 - Compose #pw+CODE+1#.
4 - The Nokia E51 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E51 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia E51
Sep 13, 2014 • Cell Phones
4helpful
2answers
How to be turn on Display light Nokia E61i Mobile????
Go into settings and open phone settings and then display settings
4helpful
I am not able to change theme in nokia e63. actually i installed a new theme yesterday and applied it. but after that e63 is not supporting so many operatins. i just want to change the theme now,...
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
2answers
Nokia e51 wont turns on only notification light always turns on when we attach battery in mobile pls help me retrieve out data over there in mobile
Hey veevec try to remove the carbon from battery and the copper which is present in the mobile where battery is touched
If there is no carbon
-> Is the battery fine (like no fatness , leakage or too much old or uncharged) * then change the battery
-> Is the mobile show a light on the screen * then try to format is by using
* + 3 + call + on/off button
And please reply me if my solution helped you please ....
Sync Nokia E51 with Thunderbird
I'm using funambol, it's very simple to and I really like it.
http://www.funambol.com/.
Works great!
Good luck.
4helpful
Nokia E51 does not display text on web pages
I had installed an arabic application the problem started.after uninstalling it every thing came back to normal.
2answers
Nokia N70 problem
try pressing going for a soft ware upgrade must solve it
3helpful
2answers
Nokia e51 wont turn on,notification light comes on but nothing on the screen
same here. the phone has not had any major problems for 10 months. I was on the phone when there were two separate incoming calls. I hang up and call the first one. Hang up once again, open the phone book to make a new call. The phone got stuck in the phone book, backlight became very strong. It was like this for 5-10 seconds, until i took the battery out. Now it won't "boot". The backlight, notification light and the ******** indicate that the phone turns on, but it doesn't continue from there.
I
Nokia E51 Smartphone Logo
Top Nokia Computers & Internet Experts
Ekse
Muzahura Frank
k24674
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
