If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
SOURCE: Controls Don't Work
I have this EXACT SAME problem with my Insignia 26" LCD TV. I was three weeks out of warranty when it happened and Insignia wouldn't do anything to help me. I brought it to three repair shops and each repairman said that they couldn't guarantee they could fix it even IF they got the right parts. Anyhow, the TV repairman had it for three months (getting parts shipped from Asia, repair time, etc.) and he couldn't fix it. He also told me that tons of other people have the issue and that Insignia is replacing their TVs under warranty. So, if your TV is still under warranty, call Insignia. You just have to pay for shipping and shipping insurance. Hope this helps!
SOURCE: Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at www.insignia-products.com. Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
SOURCE: Programing Remote
1343 or 1005 are the codes - press the TV mode button and the OK button together - the release at the same time - the top row of mode buttons needs to blink twice - then enter the code - the TV button should blink 2 times - try the power and volume buttons - if it worked then be sure to press the ATT mode button again after so you can change the channels
SOURCE: sylvania ld320ssx remote code for att uverse
Try 1864. It worked for a Media-Com remote, when none of the other codes worked.
SOURCE: Insignia lcd tv model ns-ltdvd26 has sound but no picture
the pic attached is an electrolytic capacitor, they come in different sizes and are usually blue, black and sometimes yellow. depending on manufacture.
most of the problems I have heard of tvs having problems with the
electrolytic capacitors going bad. if you open the tv and see one of
those swollen or leaking you need to replace them.
