Question about Haier HDP18PA Stainless Steel Free-Standing Dishwasher
The drain Pump on my Haier HDP18PA keeps running. I manually poured water into the drain, it pumps that water out fine. But it will not engage into "Wash Mode" because the drain pump keeps running. Yes i get the "Beeping" problem....for about a month i was using the "TIP" method and it would work....but now tipping the Dishwasher does not work anymore. Anything i can do ?
Posted by stevemannski on
4 Related Answers
orangehigh
SOURCE: need user manual
http://www.compactappliance.com/ownersmanuals/haier/HDP18PAownersmanual.PDF
here you go
Posted on Feb 24, 2008
Anonymous
SOURCE: Haier HDP18PA
Not sure of the background on your fault, but this may help:
I have an HDW202. I accidentally opened the door while it was running - a no-no, but there is no lock preventing opening the door while it is running - not idiot-proof at all, disappointing, really. Anyway, closed the door, the washer kept running, then water started to leak out the front door. I quickly turned it off, mopped up the water, and turned it back on. It pumped out the remaining water visible in the bottom, then started flashing lights and doing 10 beeps in a row, pausing for a minute, 10 beeps in a row again, etc. - it was stuck in this cycle. I tilted the unit forward, backwards, and side to side, while turning it on and off periodically to check for results. More water came out of the unit, and it started to behave normally while tilted, but not level. Eventually, after more tilting, it returned to normal behaviour when level. It seems it did not pump all of the water out initially, and this was causing it to malfunction until all of the residual water inside had drained onto the floor from tilting the unit.
Posted on Mar 10, 2009
Anonymous
  • 9 Answers
SOURCE: Haier Dishwasher hdp18pa - Power reset
Are you blowing a fuse or throwing a breaker? Either way there is a chance that no outlet you have chosen to test with yet is on a circuit with sufficient amperage-I had this with a microwave I recently had installed. If you have the manual, check for requirements regarding amperage. You then need to be sure you are using an outlet with amperage comparable to the requirements-this is on your fuse or breaker. If your requirement is, say, 20 amps, a 15-amp or less breaker or fuse is going to fail. I had to go to a 'clean' circuit from my garage with nothing on it to find out I did not have enough amps in my circuit. My solution was a dedicated breaker. Another option is to use my second option (which I did not need), to plug it into a gas generator with sufficient wattage/amperage. This ensures nothing else is on the circuit.
Failing all that, it could be the power supply for the washer, a circuit board issue, etc. Don't mess around if you don't understand electricity, though-it's not worth frying yourself.
Finally, if it worked ok before and this has just begun to happen, I'd tend to think it's an issue with the washer itself. Hope this helps.
Posted on Jul 07, 2009
Anonymous
SOURCE: Replacing drain hose of Haier portable dishwasher HDP18PA
how do i get to the hoses on maytag portable dishwasher
Posted on Jan 12, 2010
ANY IDEAS AS TO WHY MY MACHINE HAS STOPPED DRAINING? PLEASE
washing machines engage the drain pump at the beginning of a spin cycle
If there is still water in the tub after the spin then the pump is not working to pump the water out
I would check for something stuck in the impeller of the pump stopping it from spinning, burnt pump motor , no
power to the pump program board /relay, something blocking the inlet to the pump
Feb 10, 2016 | Washing Machines
Not working
That is most likely related to debris in the lower are or diverter. The pump is the same for both. Most likely food in the area or pipe to the lower arm.
Jun 09, 2013 | Haier HDP18PA Stainless Steel...
HLP021-wm fills with water, goes thru wash cycle, then rinse and spin lights keep blinking and the water stays in the tub. It stayed that way for several hours until I unplugged it,tipped it over and...
Hi.
A common reason for long or no drain for blockage at the drain hose and check setting of the drain hose. If the hose is blocked or incorrectly set drain may not complete. See page ten of user manual about hose setting. Here the user manual.
If the hose is OK the problem is either water level switch or blockage at drain pump.Water level switch is located in control panel assembly. the part is a plastic disk connected to a long thin rubber hose that goes inside the tub. If the hose is dirty the switch will not detect drain is complete and drain will not finish. The pump is located at the bottom of the appliance. The hose connected to the pump may be blocked. In some case the pump itself may be defective.In that case the pump must be replaced. The parts for this unit are not expensive.
Parts can be ordered from Haier. Here the US website: Welcome to Haier America
Parts for this washer are also available here
Haier also makes available a service manual. Exploded view is not included.
The exploded view and part list are shown in the manual available here (Please download the manual and check pages 16-17 - a free subscription is required).
Regards.
Ginko.
Nov 21, 2011 | Haier Washing Machines
Jul 27, 2009 | Haier HDP18PA Stainless Steel...
Haier HDP18PA
Jan 25, 2009 | Haier HDP18PA Stainless Steel...
ASKO D1986: Water pump running constantly
Solved by draining water from bottom pan.
Jan 18, 2009 | Asko 24 in. D3350 Dishwasher
Haier washing machine E2 error
normally pump filter is the best place to start it could be jamed with a coin or hair clip if you take machine outside and empty it then lay it on its side you can access the pump take it off then stand up the machine and pour hot water into the soap draw check water should run out of bottom freely taking any fluff or bits with it now take apart the pump and clean it all out dry all components before reasembly if the machine still doesent wory could need a new pump
Sep 07, 2008 | Haier XQG50-11 Front Load Washer / Dryer
The washer keeps beeping and trying to drain as soon as it is turned on
I have a Haier HDP18PA with the same problem... I tried tilting mine backwards while running...this made a mess BUT the beeping stopped BUT the lights were still flashing. Turned it off and started it again and the lights still were flashing BUT no beeping. Decided to try tilting it forward while running ... made another mess BUT the lights stopped flashing. Turned it off again and restarted it and it is now running fine. Good luck!
May 05, 2008 | Haier HDP18PA Stainless Steel...
Pump not draining - Haier portable dishwasher
purchase new pump at www.partsquick.com/haier
about 33 shiped must be able to replace if they sell the pump i have the same problem looking for a diagram to replace pump
Feb 03, 2008 | Haier HDP18PA Stainless Steel...
Haier HDP18PA Stainless Steel Free-Standing Dishwasher Logo
101 people viewed this question
Top Haier Dishwashers Experts
Marvin
Marvin
Peter
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
