SOURCE: Where can i find the passcode for my rocketfish
Try 0000
most devices have a default code.
this one seems pretty common.
You can reset your code in most cases. Read the manual.
don't forget to rate me!
SOURCE: How can I boost the signal on my rocketfish
There is no BOOSTER to do it,but you can do it for a router.Depends on your route rmodel there is several router signal boosters online.
4 reviews - $10.02 - Amazon.com
2 pack Wi-Fi Wireless Antenna / Router Signal Booster
Shopping results for wireless router signal boosters
3 pack Wi-Fi Wireless Antenna / Router Signal Booster
$7.99 - Buy.com
2 Pack Wi-Fi Wireless Antenna / Router Signal Booster
$8 - 2 stores
SOURCE: lost mounting plate. Rocketfish says they
http://www.mcmelectronics.com/product/WFC6653-02
Oddly this is Rocketfish's parts provider, no idea why they told you that. Its on backorder though atm.
SOURCE: i have a rocketfish 1025
Well, first let address the lack of power usage from your router and cable modem. The router, depending on model, may only use less than 5 amps of of power, depending on the load it is using at any one time, the cable modem is using maybe 2 amps, at peak load, since the line is already powered from the cable company, there is no real load. Since the usage is much less than 1 watt, it would not register on your meter. The reason why unplugging your devices from the wall, for it to not provide backup power to all of the devices is the battery(ies) may not be providing enough juice to maintain the power required for ll of the devices plugged in. Also, UPS are generally not compatible with power strips and therefore do not tend to function properly with a devices powered on the strip. They generally won't complete the power connection due to the strip carrying a much higher load than the UPS can support. This should explain all of your power issues. If you require additional information, please do not hesitate to ask.
