SOURCE: Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
SOURCE: hotpoint refrigerator water dispenser not working, while ice maker, works slower
Check or replace the water filter
SOURCE: ice dispenser in door clogged up or frozen
I would contact Hotpoint direct for this one. It sounds like a design fault to me.
What I think may be going on is that the cubes are melting too much, then refreezing lower down.
Set your freezer to -18, and the fridge to +2 and see if that changes things any.
Check seals in that area. Where is the moisture coming from to generate the frosting? - Is the location high in humidity?
SOURCE: Hotpoint CSX22GR water dispenser not working
Sounds like to me your filter needs replaced...how long ago have you changed them?
SOURCE: water dispenser doesn't work on ge hotpoint freezer
Here recently I have run into 2 of these units that do this and have found that the dispenser line is frozen in the freezer door. The way to test this is to remove the kick plate under the doors (It is easiest to open both doors to do this) Disconnect the union in the water line leading to the door by pushing in on the waterline and pulling in on the end of the fitting. When the line is apart, close the doors and push in on the paddle as to fill a cup with water. If you get water out of the line under the door then your line in your door is frozen and you will either need to replace your door or let the unit thaw for 24 hours with the doors open. Cheaper to thaw. If no water comes out under the door when paddle is pressed then you will need to replace the water valve as long as you have 120 volts at the valve when actuated.
