Question about Night Owl Optics 8 CHANNEL H264 DVR WITH 8 CAMERAS
I have night ow dvr and forgot the admin pwd - Night Owl Optics 8 CHANNEL H264 DVR WITH 8 CAMERAS
Posted by Umer Hayat on
Radio Code Pro
  • 2,200 Answers
The default password for this unit is 111111
If you have set a different password and cannot remember this you must contact the Night Owl technical service department directly for a factory reset. There is no other way of accessing the unit if the default password has been changed and you have forgotten it.
In the event that the default password is changed the contact details for Night Owl Technical support as follows;
Night Owl 75 West Street Walpole. MA 02081
Toll free Phone : 1-866-390-1303
Website: www.NightOwlSP.com
Email: [email protected]
Hope this helps. Please remember to leave a vote for the solution. Many thanks.
Posted on Aug 30, 2011
Ellen Mago
    New Friend:
If you are in the start up wizard, will need to exit out of it. To do this, reboot (simply unplug and then plug back in) the DVR once its fully up and running the Start up wizard will appear. Select Exit and from the right click anywhere on the screen and a log in box should appear. Follow these steps below.
1) log in with the master password- 380761
2)Go to main menu
3)select advanced on the far right
4)In the menu below select "Load Defaults"
A) in that mini window select SYSTEM and nothing else and then save
B)once done it should say, save parameters success
5)GO to the main menu again and then system this time
6)ON the left select USERS
A) highlight the admin account so that its blue
B) Click edit at the bottom
C) Set your new password, needs to be 8 characters and is case sensitive
D) Under the "enter current password box" leave blank
Posted on Jan 28, 2016
  • 6 more comments
  • Anonymous Apr 24, 2016
    log in with the Admin and master password- 380761 is correct for the 4 channel Night Owl DVR Too. Thanks you . NightOwl support are no help. I give you 10 stars .
  • Marcus samoa Dec 29, 2016
    It doesn't give me the option to exit startup wizard even after restarting the dvr
  • Bonny Sanders
    Bonny Sanders Jan 19, 2017
    I can't exit startup wizard either--what's the secret?
  • Valmick nanan May 14, 2017
    Can't get in the DVR to go into any program it lock
  • Valmick nanan May 15, 2017
    Could you please help me unlock my nightowl 8 channel system
  • joana
    joana Jul 24, 2017
    please help me, I Forgot the password my nightowl 8 channel system
  • Erabu Johnmoses
    Erabu Johnmoses Jul 10, 2019
    Please help me I forgot the password for my nightowl 8channel system yet I don't want to loss my data
  • Timothy Echols
    Timothy Echols Sep 17, 2019
    I bought my night owl DVR from a pawnshop and rite away it's asking for a passcode . Model number F6-DvR8-1TB how do I reset to factory
Gotta love me
    New Friend:
Go back to your email where you register and it should be there
Posted on Feb 25, 2017
I purchased a NIGHT OWL modelxhd50288p 8ch v 2tb 5mpcam system and forgot pw and dvr is locked how can i reset it
hello friend. idont known much about this night owl model dvr.but i can suggest small technique which we use i n chinese dvr.open the dvr look for 2030 small battery fixed in the board remove it .start your dvr reset to factory setting once then insert the battery again.i hope your dvr is ready.
Oct 25, 2017 | Night Home Security
I forgot my admin password i got a H.264 dvr 4ch China made
Admin and Passwords come as default. If you changed it and forgot, try unplugging the DVR and restarting. You can also still open the settings and try to re- factory the DVR if the settings permit. Next, I have to assume that you got the Booklet or the email or URL addresses to download same.
There is in the hand book the default password as the User name:password and the Password #'s 1-6. Good luck.
Sep 09, 2015 | Home Security
Forgot admin password in Hifocus H264 DVR, unable to enter main menu
Hi. Put here some images of the DVR's front side, the login screen and the WEB interface.
Jun 15, 2015 | Home Security
FORGOT PASSWORD DVR ECOR264-16X1
Thhe Factory Default is.
For user type in : admin in lower case .
for Password Type in : 11111111 .
thats 8 # 1 .
Sep 15, 2014 | EverFocus Ecor264-16x1/2t Dvr Digital...
How do you reset the admin password on a truvision dvr 30 16 channel.
how do i reset admin password on a truevision dvr.
I have changed it and i forgot it
Jun 29, 2011 | GE Security Kalatel TVR3008500 TruVision...
How to reset ie admin password for night owl scorpion
If your DVR is networked you can use this utility to recover the passwords
http://seanmsiegel.com/blog/raysharp-password-hack-exploit/
nightowl dvrs seem to be made by raysharp
Jan 10, 2011 | Night Owl Optics Night Owl Scorpion 168500...
I need reset the password on a 16 ch. dvr dvs do you know how i can do this?
I have a H.264 Network DVR with ver. V2.00.R05 and I've forgotten the password can anyone help with resetting it...
Mikw
Nov 05, 2010 | CSi Speco Speco DVR-T4IP 4-Channel Triplex...
We have an Avocent ACS32, that we 'forgot' the Admin pwd to.
start the unit single user mode by hitting space after Linux/PPC Load: .... and typing single and hit
use the passwd command to change password and saveconf to save the password
Dec 15, 2009 | Avocent Cyclades Alterpath ACS32 (ATP0105)
Admin password DVR-X4 IP
i lost the dvr password how to watch yastaday data
Mar 11, 2008 | CSi Speco Speco DVR-T4IP 4-Channel Triplex...
Night Owl Optics 8 CHANNEL H264 DVR WITH 8 CAMERAS Logo
64,790 people viewed this question
Top Night Owl Optics Home Security Experts
Lawrence Oravetz
Nitin Khatri
Nitin Khatri
Are you a Night Owl Optics Home Security Expert? Answer questions, earn points and help others
