Question about 2wire Wireless-G 802.11g ADSL Gateway
My laptop is in the living room, my 2WIRE router in the bedroom. When I turn on the MAC it sometimes indicates that I am not connected to the Internet. I then have to fool around with diagnostics to try and reset it. Is it possible that the router signal is too weak? If so how can I boost the signal? Thanks Ken C
Posted by kencun17 on
Perry Bailey
    New Friend:
  • 26 Answers
The easiest way to know if you have a weak signal is either by the indicator bars for the signal, or if the connection improves as you get closer to your router.
Your router might be getting weak and isn't transmitting like it should, or you could have too much interference such as a large appliance between the router and the laptop, or a thick wall, etc...
You can buy a signal booster for the house or run 2 wifi routers too.
The other possibility is the wifi card in the laptop could be weak as well.
Posted on Dec 09, 2017
James Hensley
    Sergeant:
    Habit-Forming:
  • 161 Answers
I would boost the signal it can only help I had the same sort of problems but my wireless router quit working properly my iPad wouldn't pick up signal so I had to replace my wireless router hope this helps Merry Christmas
5 Related Answers
Anonymous
  • 366 Answers
SOURCE: Set up wireless internet access using HG1701 2wire router
Check with this tip
Detail on this Wlan Router
"Connect power cord to router.
Wall Plate -> Router (using phone cord).
Router -> PC (using network cable).
  1. Power on router, when the lights settle, start the PC.
  2. Start IE in PC, type 192.168.1.254 in the address bar and press enter.
  3. Start configuring using the Telco's suplied info, namely PPPoE username and password. All other function works by default.
  4. The WEP key is the 10 digit number underneath the router (not the 12 digits S/N number).
Posted on Jan 20, 2009
noti13
  • 15 Answers
SOURCE: Connecting 2wire modem./router to extra linksys router
to get this right you must make sure that the 2wire will be configured to be your gateway which means that the 2wire itself will be connected to the internet then set the linksys to DHCP mode because if you dont it will give you a router behind router error , make sure that the 2wire is properly authenticated and connected to the internet to make sure access the gui by typing gateway.2wire.net on your browser and run system set up wizard
Posted on Jan 26, 2009
Anonymous
  • 13 Answers
SOURCE: 2wire gateway signal range problems
1. Put the router in the highest location possible in the house.
2. Make sure the gateway is installed in the center of the house rather than in a corner of house, so it will cover area on all sides.
3. Make Sure you dont have any devices that may interfere with the signal eg. cordless phone , close to the gateway.
4. Use channel 3 or 7.
Posted on Mar 23, 2009
Damilare
Dammy Ezekiel
  • 358 Answers
SOURCE: I have 2WIRE wireless router i have 2 pc's Pentium
Ensure that you are using a crossover cable to connect the two routers together, if thats not what you are presently using, then make sure that you are allocating different static I.P Addresses to both of them.
But if what you are saying is that you are trying to connect the separately, and not together to the network, and its not working like the first one, then I suggest that you return it to the point of purchase, if you still have the warranty card, before its too late.
Hope this helps.
Posted on Jul 15, 2009
Anonymous
  • 164 Answers
SOURCE: Connected but no internet
del everything in %temp%, if you are using internet explorer, reset it back to factory by..in IE7 select,tools,internet options,go to advanced tab and click reset. Be advised, Vista is notoriously difficult when it comes to internet connection problems especially wireless.
www.aa1consulting.com
Posted on Jul 24, 2009
1helpful
Can I connect a second computer (not a laptop) in my bedroom wirelessly to the 2wire modem that I have connected to my main PC?
Yes, you can. just make sure that the computer has a wireless capability, if not then you need to connect a wireless adapter so you could connect the computer to your 2wire router wirelessly. Another possible way to have it hooked up to your 2wire router is via Ethernet cable but depending on the distance you may need a longer cable.
Have a 2Wire Router from SBC that has recently been causing connection problems with my sons XBox. Low signal roughly 2 bars. Nothin has changed in the house. Have router in main bedroom, Xbox is in son's...
if signal is fading in and out there are a lot of factors. 1 have you installed an other electrical epuiment in the house? emf cause interference. 2 if you move the xbox to the same room as the router how is the signal? d3 do you have a laptop to try next to the xbox where it is at now and see the signal? if it is weak on ther laptop also get a new router.4 if the signal is good on the laptop your xbox is the problem.
1helpful
Linksys WRE54G
after hooking the linksys router to the modem hit the reset button on modem. this will allow it to set it up in dhcp and recognize its mac address.
I have a Arris Modem from time warner cable, no i
do you have dsl filter where the phone line comes out of the wall and goes into the Router.
https://en.wikipedia.org/wiki/DSL_filter
Problems moving the router and getting the internet.
your bedroom cable phone plug has issue.
These is not dial tone or low voltage problem in line.
So just replaced that phone cable and jack .then check.
1helpful
Router issues in my apartment.
When to moved into the penthouse, there are more walls between the wireless router and the laptop in the bedroom. The walls are probably reinforced concrete walls which will stop or weaken the radio waves penetrating into different rooms. When you lived in a house this was not a problem.
The only way to solve this problem is to move the wireless router near an opening such as a door and move the laptop as close as possible to the wireless router to get a better signal strength.
The outer way is to install a wireless repeater or connect a long network cable to the router and the laptop.
2answers
Wireless Troubles with 2wire
you need to check the wireless encryption for your 2wire modem..
Painfully slow desktop internet use
I would start with running network setup wizard again on my desktop. also run a full system test at pcpitstop.com and see what all it tells you. If you are running a 2-Wire..GIVE IT BACK. spend a couple of bucks and get a linksys.
James Mac
Connecting belkin router
Hi!
How far are you away from the router to the bedroom?
What do you mean by "bedroom system"? Is it a wireless computer?
Open Questions:
See all 2wire Wireless-G 802.11g ADSL Gateway Questions
2wire Wireless-G 802.11g ADSL Gateway Logo
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
