SOURCE: drum reset for Panasonic kx-mb781
There is a little special (white) gear on the outer left side of the drumkit - a little bit below where the toner sits. That gear joins with toner mixing assy - and you can rotate it in counterclockwise all the way back. This should reset the drum counter - worked for me - I hope it also does the trick for you ;-)
SOURCE: reset drum
I think this machine does not have a reset option instead you can reset manually.All you have to do is on the right side of drum unit there exist a white + type notch,rotate it clockwise till it allows.Put back drum unit into machine.Switch on and see replace drum and supplies message will disappear.In my case it worked.Hope this is the best solution.All the best
SOURCE: need Panasonic WORKiO® DP-2330 driver
Hello , this is the link for the most up to date driver. Just choose your language and operating system
Thank you.
http://www.panasonic.net/pcc/support/mfp/dp-3030/gdi/download.html#01-2
SOURCE: What does e0122 error code on panasonic workio dp
the best solution to that problem is that there's a dirt on the shafting of the polygon motor, try applying some lubricant to make the polygon motor go smooth.
SOURCE: workio dp 6030
The drum density sensor is covered in toner and needs to be cleaned. this is a job for a trained engineer.
