Question about Keurig B60 Coffee Maker
During a power surge (Hurricane Irene) our coffee maker does not work. I work at Milford Middle School in the Quakertown School District and the coffee maker was donated last year by a parent. Could our coffee maker be replaced. We have no sale slip because it was a gift. The staff loves the coffee maker and we are very lost without it.
Posted by dkoder on
D. Floyd Kolb
  • Keurig Master
  • 43,501 Answers
I would call Keurig directly... they are usually very generous with their replacement policy...
The problem is often that the machine develops a leak in thehose that is right over the transformer...the water drips onto the transformerand kills that... then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Posted on Sep 02, 2011
What schools are near 2801 Dayton street in st. louis mo. 63106
First call the government office of St. Louis, Missouri, and find out the name of the school district.
Then call the offices of that school district.
Ask them the question.
If you cannot find the offices of the government, try asking the police department, the fire department, the Better Business Bureau, or the Chamber of Commerce.
God bless your efforts.
Jan 21, 2016 | School Zone Computers & Internet
The machine does not give any water when I make coffee
Hi Irene, The heating coil may be bad. Try to make some coffee and after a minuet take out the carafe and see if its hot.(using caution). If the hotplate is cold after a minuet of use the heating coils are not working. This can happen from no electric, loose connection at the outlet or the coffee maker or a bad heating coil. Hope this helps, Tom
Mar 28, 2015 | Coffee Makers & Espresso Machines
How do I fix my Keurig B60 SN#65.0100.3601827 power won't turn on?
It sounds like your power is off. all should be fine when it is restored.
Jan 27, 2015 | Keurig B60 Coffee Maker
Saeco Incanto Sirius doesn't turn on. Outlet fine. Is there a main fuse to check/reset? Other suggestions. Hopefully it didn't get surged with Hurricane Irene.
We have here the map with service support but as you can see they to have for the moment any at CT. However you can check if any other area is the best for you.
Sep 01, 2011 | Saeco Incanto Sirius Fully Automatic...
Does not power up. was on a surge protector. lost power in building several times during hurricane Irene
A surge protector is there to protect against high spikes in electricity and not fluctuations.
The possibility exists that the components were damaged due to fluctuations in the electricity received by your computer. It is for this reason that an UPS or Uninterruptible Power Supply would most likely have saved your computer as it helps provide your computer with a smooth supply of electricity.
One would assume that the power supply is somewhat toast however in most cases it is unfortunately the most fragile component that goes first, being the mainboard. See my published guide to help and diagnose the faulty components, entitled
My Computer is not turning on!!! Is it dead!!! No POST!!!
Make sure that the wall outlet is working, test it by pluging a device into the outlet, check that it is being powered. Also in some computer power plugs a Fuse is placed within the actual plug. If this is the case then you may be in luck as it would then be possible that the fuse is blown. One would then replace the fuse and presto good as new.
Let me know how it goes!
Take care!
damnor01
Aug 30, 2011 | Acer Veriton 6800 PC Desktop
We were without electricity for 2 daya following hurricane Irene. When power was restored, the oven display (time, temp, etc) did not come back on. The oven lights come on when the button is depressed. and...
Try turning off the circuit breaker to the oven for 30 min or so and then turn it back on. If it does not come back on the oven probably got a power surge and the control has been damaged. Hope that helps
Aug 30, 2011 | Whirlpool RBD305PD Electric Double Oven
I work for a school district and we have at least 23 110-150 cup Alfa coffeemakers, and 25 50-cup Alfa coffeemakers. Many of them are experiencing various problems. We do not have manuals so we cannot...
I feel, that with that many coffee machines and garoua problems, you would need a local coffee repair man to come out and go through them and get them up to par, then figure out a low cost, yet effective maintenance program. Lots of local coffee companies would glad to help for little or no cost for trade of in house or local advertising in school papers and pamphlets. Let me know what you think if this helps , thanks mike
Jun 08, 2011 | Coffee Makers & Espresso Machines
I have a cuisenart dcc 2200 coffee maker. We had a power surge.
mcdevito75, Unit coild be burned out from power surge, Test at a known good electric outlet. If burned out replace your coffee maker.
Jun 22, 2010 | Cuisinart Brew Central® DCC-2200
Keurig B60 Coffee Maker Logo
141 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Vincent G
Vincent G
Colin Stickland
Colin Stickland
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
