Skype IM Logo
Posted on Aug 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Skype won't run on my computer,it says some files are not there for skype to work
Alli Abiola
Level 2:
Champion:
  • Expert 256 Answers
  • Posted on Sep 24, 2011
Alli Abiola
Expert
Level 2:
Champion:
Answers
256
Questions
0
Helped
29764
Points
438
It means Skype will no work because it needs some file to launch. uninstall that one and download another one.
Missing files to run skype
It could just be a confused shortcut. Try and Run it from it's actual file location. If it still breaks it's internal to the application. Delete through Control Panel then...
Download and run a new install from here:
http://www.skype.com/en/download-skype/skype-for-computer/
May 03, 2012 • Skype IM
tip
How can I run two Skype accounts on the same computer?
To use more than one Skype account on the same computer at the same time you need to start a new instance of Skype.
1.
From the Windows taskbar, click Start > Run (or press the Windows and R keys on your keyboard at the same time)
2.
In the Run window, enter the following command (include the quotes) and press OK:
"C:\Program Files\Skype\Phone\Skype.exe" /secondary
If you get an error message, copy and paste the exact command from this page and try again.
Be aware that if you have changed the installation path for Skype then you will need to enter the correct path for the Skype.exe file.
If this solution fails, you can try another option:
1.Find the Skype executable file (Skype.exe) in: C:\Program Files\Skype\Phone\
2.Right click on it and select Send to > Desktop (create shortcut)
3.Locate the shortcut on the desktop, then right-click on it and select Properties
4.In the Target field, add: /secondary. The Target field should now be "C:\Program Files\Skype\Phone\Skype.exe" /secondary
5.Click OK. You can now start a new instance of Skype every time you double-click the new shortcut.
My skype won't turn on.
internal incompatibility with something you have running at the time. Probably your proprietary Firewall.
Jan 24, 2012 • Skype IM
4helpful
I want to creat new skype id
I got your answer from: https://support.skype.com/en-us/faq/FA829/How-can-I-run-two-Skype-accounts-on-the-same-computer
In order to use more than one Skype account on the same computer at the same time you need to start a new instance of Skype:
  1. From the Windows taskbar, click Start > Run (or press the Windows and R keys on your keyboard at the same time)
  2. In the Run window, enter the following command (include the quotes) and press OK:
If you get any error messages, please copy and paste the exact command from this email and try again.
Please keep in mind that if you have changed the installation path for Skype then you need to enter the correct path for the Skype.exe file.
  1. Find the Skype executable file (Skype.exe) in: C:\Program Files\Skype\Phone\
  2. Right click on it and choose: Send to > Desktop (create shortcut)
  3. Locate the shortcut on the desktop, then right-click on it and choose Properties
  4. In the Target field, add: /secondary. The Target field should now be: "C:\Program Files\Skype\Phone\Skype.exe" /secondary
  5. Click OK. You can now start a new instance of Skype every time you double-click on the new shortcut.
For Skype 3.8 and earlier Requirements: Windows XP, Two Skype User accounts
First, create a new Windows user by going to the Control Panel and clicking on User Accounts. Choose Create a new account and follow the steps to set permissions. We also suggest setting a password for the new user by clicking on the newly created user and choosing the Set Password option. The new user will also require admin rights on your PC.
Next, create a shortcut to Skype or make a copy of the shortcut that is already in the Start menu. Right-click this new shortcut and choose Properties. On the bottom of the first page there is a button labelled Advanced... . Click this button and select Run with different credentials. Select OK, and then select OK again to close the Properties dialog.
You're all set. Whenever you use this new shortcut it will ask for a Windows username and password. Enter the Skype Name and password of the user you created earlier by choosing The following user: option. Click OK and you'll have a second instance of Skype. It will require that you sign in with your Skype Name and password the first time.
To help automate the Run as trick you can create a second desktop icon for Skype and modify its properties. Click the Advanced button and check the box Run with different credentials. After clicking on the modified icon it will ask you to sign in as another user. Changing the icon graphic also helps ensure you click on the correct icon.
If you have multiple USB headsets or USB Phones you should be able to set up both instances of Skype to use a different sound device.
Dec 02, 2011 • Skype IM
Skype has stopped working
Please go to this link http://www.skype.com/go/downloading Then download and save the file to your computer desktop do not run that file. Then go to computer control panel then uninstall Skype from the program list. Then you can run the skype file that you have downloaded earlier.
I have Windows Vista and Internet Explorer 9. Skype was fine and now won't even open. A small box comes up saying 'Skype has stopped working'. I have checked for updates. Help please!
Try this, (Vista & Win 7)
1. Close Skype
2. Exit the Skype icon from the system tray(at the bottom right of the screen)
3. Ensure that "Show hidden files and folders" is switch is check & enabled
(i). Start-> type "Run" & press Enter
(ii). Type "control folders" & click OK
(iii). Select the View tab & ensure the relevant entry is enabled
4. Locate the shared.xml file
(i). Start-> type "Run" & Press Enter
(ii). Type "%appdata%\skype" & click OK
(iii). Delete the "shared.xml file" - (without quotes)
Restart Skype, a new shared.xml file will be created.
Hope it will help.
I'm trying ti install skype on my computer and get an error code #1618 , I have an account set up and all that.
Please, first try to re-boot twice, more here:
http://www.installsite.org/pages/en/msifaq/error/1618.htm
If that does not work, then please try the below.
Please follow these steps:
* Copy Skype setup file to desktop and rename it SkypeSetup.exe
* Click Start
* Run
* type "cmd"
* enter
* type "cd desktop"
* enter
* type "SkypeSetup /log"
* enter
* Skype install will start with logging enabled
* Try to install it.
* Install created one text file to desktop please attach it to here
May 31, 2011 • Skype IM
When enter my log 0n I receive this message: Skype has stopped working. A problem caused the program to stop working correctly. Window will close the program and.................. This happened...
Skype changed in the update. You probably have yours set to run in compatibility mode for Vista Service Pack 2. This crashes the program now. Only fix I've found is turning compatibility mode off, which sucks cause it won't minimize to tray. But it runs at least.
May 16, 2011 • Skype IM
I am trying to download skype for my laptop. I keep getting the error 1618. I have restarted my computer and tryed to find any files on my registry, but still no luck
Download ccleaner and run it.
After that, at the RUN menu
type "temp"
And; type %temp%
Delete all the temp. files and folders present.
Before downloading the latest version of skype
Delete any file related to skype.
You can check in C:\Program Files\Skype....
ok
try this
Feb 21, 2010 • Skype IM
Top SKYPE Computers & Internet Experts
k24674
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
Are you a SKYPE Computer and Internet Expert? Answer questions, earn points and help others
