Samsung PCH521R 52" Rear Projection Television Logo
Question about Samsung PCH521R 52" Rear Projection Television
My samsung tantus shows picture but no sound - Samsung PCH521R 52" Rear Projection Television
Posted by chester_mala on
Anonymous
    New Friend:
  • 142 Answers
There is "audio out" jacks on back side of television. connect it to an amplifier or other tv & hear if sound is comming. if sound is comming then audio amplifier is defective in your tv. if sound is not comming then audio processor may be defective.
Posted on Aug 30, 2011
I just put a new lamp in my tv (42" samsung tantus) and the temp light is coming on.
Samsung Tantus used TV says Check Fan # 2 ? and will Not respond to any commands Nor show anything but Blue back ground and Flashing FAN warning ?
Samsung Tantus Picture Problem. Green Yellow Black Hue
it seems that your unit got loosed contact.i mean it needs resoldering.call a technician to do further troubleshooting.
Samsung Tantus problem
your main power supply is gone out
2answers
Our Samsung Tantus Rear Projection TV, the colour is a problem, on the right hand side there is a red shadow next to the picture so it almost seems as if the picture is doubled. I have a double picture...
Sounds like a convergence issue with your RGB colour channels - probably need to get it serviced and have the convergence tuned.
Unlikely you can do this yourself.
Papa
Samsung 52" tantus pch521r convergence panel
I found a this SITE that carries that convergence assembly for your TV.
Good Luck.
2answers
Samsung tantus 1080i
hi i have a 47" samsumg tantus tv and i haven problem with the screen. has some red lines
Samsung 52" tantus pch521r no picture
1) Loss of color = bad solder connects on signal board
2) Loss of pix = probable CRT coolant leak onto signal board
Have a technician check it out.....can be expensive......T.
Samsung Tantus - turning on and off... on and off...
have the main power supply checked sounds like its weak or out
Open Questions:
Marvin
Marvin
