Hello there,
Please follow the steps below to be able to replace the lamp,
Hope this helped.
Goodluck
Elect_Comp
Welcome to FixYa.com
Park and Turn Signal and Daytime Running Lamp Nuts (Qty: 3) Tip Disconnect the forward lamp harness connector from the lamp
socket
Thank you for using FixYa.com
Regards, Lee Davidian
Welcome to FIxYa.com
BACKUP LAMP REPLACEMENT REMOVAL PROCEDURE 1. Open the rear compartment lid. 2. Remove the rear compartment lid trim. 3. Pull back on rear compartment trim panel. 4. Disconnect the backup lamp connector (5) from the rear
compartment lid wiring harness. 5. Press the grommet (3) out of the rear compartment lid. 6. Remove the fasteners (4) securing the backup lamp (1) to
the rear compartment lid (2). 7. Remove the backup lamp (1) from the rear compartment lid (2). INSTALLATION PROCEDURE 1magJ 1. Route the backup lamp connector (5) and the grommet (3)
through the rear compartment lid Q). 2. Install the backup lamp (1) to the rear compartment lid(2). 3. Install the fasteners (1) in order to secure the backup
lamp (I) to the rear compartment lid(2). NOTE: Refer to Fastener Notice in Service Precautions. Tighten Tighten the fasteners to 4.5 N.m (40 lb in). 4. Verify that the grommet (3) is filly seated in the rear
compartment lid (2). 5. Connect the back-up lamp connector (5) to the rear
compartment lid wiring harness. 6. Install the rear compartment lid trim. 7. Close the rear compartment lid.
