Question about Sony PlayStation 2 (PS2) Console
When put the ps2 power to on it never starts nor the red light . i opened it once,i removed the strip of the reset and power switch but i don`t know were to fit it . pls help me
Posted by teenagerokz_ on
khorianne5
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 273 Answers
Try here:
http://www.slideshare.net/Bravo77/ps2-repair-guide
Look for the Eject Ribbon cable section of the guide.
Hope this helps :) and good luck.
Posted on Sep 03, 2011
GFWH1200DWW GE front load washer won't unlock red lock showing
From an article I found online:
See if manually opening the door will reset everything. Unplug the washer and remove the lower front panel like you're going to clean out the drain catch. Once you remove this panel you can reach up behind the upper front panel and pull down on the small plastic pull tab attached to the bottom of the door lock assembly. This will manually unlock the door so you can open the door.
Now once you have the door open, plug the washer back in and see if you can start another cycle.
Mar 06, 2016 | GE Washing Machines
How do you fix a broken stop switch on a 455 rancher
The stop switch is just a red plastic rocker that connects the earth cut out wire from the ignition unit, to a grouding wire to cut the ignition,it can be changed on the machine, however it is much easier to remove the air filter housing, start by removing the screws, two at the top and two at the bottom, disconnect the earth wire and the earth return wire, the upper wire has a spade conection onto the earthing strip, the lower wire also has a spade conection but just pushes into the red ignition rocker switch,unhook the choke from the carb, once the housing is removed gently pry out the blue choke pull from the housing, once removed pry off the broken rocker switch, this is sprung loaded via the earthing strip, pay close attention to how this is fitted, so as you know where to re fit if ( take a photo with a mobile phone to help with re instalation )now fit the new rocker switch, re install the earthing strip, re fit the choke pull, re assemble the air filter housing onto the back of the carb, re connect the wires.
Feb 26, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
The on/off switch won't turn on. i have power on (red light) switch clicks but no green light. i have taken lid off and white button seams on work but still no green light. i have even held down little...
This is one of three things. Unfortunately, it's difficult to determine which, unless you start replacing parts.
1. Bad switch. The switch doesn't usually go bad by itself, has the PS2 been dropped? Bumped? Anyone push the switch too hard? It's held in by solder on all 4 corners. If the solder becomes dislodged, the switch can fail.
2. Bad cable. This is rare unless someone opened the PS2 and removed/installed the cable a few times and frayed the internal wires.
3. Bad motherboard. Sometimes a power problem can develop, or the motherboard can short out. It's pretty rare, but I have seen it happen.
4. Bad AC adapter. Recent power surge? It's possible that the AC adapter is delivering enough voltage to power the standby light, but not enough to power the actual system on. You can easily check this by plugged your PS2 up on someone else's AC adapter or taking your AC adapter to someone else's PS2.
You can find parts at the following page:
http://store.richspsxparts.com/ve12s.html
Nov 09, 2009 | Sony PlayStation 2 Slimline Console
My canon pixma mp140 error 2 and the alarm light blinks. Help me. JJF.
try to reset your printer ---
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Mar 09, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
ACER ASPIRE WON'T TURN ON AND RED LIGHT FLASHING
acer aspire 5315 wont turn on, but the battery led lights up when the ac adaptor is connected..pls help.
Dec 20, 2008 | Acer Aspire 5315 Notebook
PS2 No Green Light
Maybe it has something to do with your power supply, try replacing it with a different one.
Jun 09, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 disk tray wont open, power light is on, eject light is off
if the ribbon cable that goes to the lens came out its gota go back it. has a plastic tab on the top that lifts up and down to lock it in place....
If its the eject/reset button the ribbon might not be in all the way
Dec 30, 2007 | Sony PlayStation 2 (PS2) Console
Ps2 slim will not power up
usually, there is a problem with a ribbon cable of power/reset switch. Try using a replacement ribbon of the same type.
Nov 01, 2007 | Sony PlayStation 2 Slimline Console
Ps2
u need to get some pliers and put it back in...i had this same problem before
Aug 20, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
94 people viewed this question
Top Sony Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
