Have you tried a different battery? Occasionally a battery can read good but die under load. Also use care when replacing the battery. Many devices today specify in small print to leave the battery out for a minimum time period (anywhere from about 15 sec to 5 min, depending on the model). Also, it is sometimes quite easy to reverse the polarity on some of these devices. If all else fails, contact the manufacturer. It's possible the unit itself is bad.
SOURCE: 1 chirp every 30 seconds
it is not the battery problem, you need to get a replacement.
the circuite board is bad.
SOURCE: Unit has been installed for 2 weeks with a new
new batteries are probably dying-- new doesnt mean they cant be faulty install new batteries and observe if problem returns quickly
SOURCE: kiddie fire alarm model I12060, beeps once every
This happened to me, my smoke detector started chipping so I changed the batteries. A few seconds later it started chirping again. The answer is in the way you put the batteries in. The smoke detector allows you to put the batteries in wrong and makes a slight connector. This slight connector tricks the detector into thinking the batteries are weak. Simply turn the batteries around so the fat connector of the battery touches the skinny connector of the device. Mine was, fat side on the right.
SOURCE: I just fixed a new Kidde alarm hardwired with both
The normal condition for the green LED is solid. A flashing green LED indicates memory of a prior alarm condition. Press the test for at least 2 seconds to reset the detector memory.
SOURCE: one beep constantly
Most new smoke detectors work off of two power sources, electric and battery backup. The battery is used to power the detector if primary electrical AC power is lost. It would be a good idea to replace all detector batteries every two years or so. You'll access the battery by opening the unit, find out the type used and then purchase a replacement at your local store. Hope this helps.
