RTC battery is located underneath the palmrest - to the left of the touchpad - they don't usually die, as they are Lion rechargeables. Unless your Satellite 1410 is losing date and time every time it is turned off, you probably don't need to replace it. But if you need to replace it, make darn sure that you replace it with a rechargeable and nothing else.
If you need to get to it, you'll need to remove the keyboard, then the square aluminum bracket above the heatsink, then get to the bottom, remove all the F6 and F26 screws, then you must make sure to disconnect the WiFi antennas. After that, the top case (including the palmrest) will unsnap from the bottom case and you'll be able to see the RTC battery.
