Question about HP LaserJet 4730mfp All-In-One Printer
Do the calibration for the scanner.
1. Place letter- or A4-size paper in tray 1, and adjust the side guides.
2. On the control-panel Home screen, scroll to and touch Administration.
3. Touch Troubleshooting.
4. Touch Calibrate Scanner.
5. Touch Calibrate to print the first pass of the calibration target(Print out).
6. Place the first pass of the calibration target face-down in tray 1 so that the arrows are facing into the MFP.
7. Touch Start to print the second pass.
8. Place the calibration target face-up into the ADF, and adjust the side guides.
9. After the calibration target has passed through the ADF once, reposition it face down in the ADF and touch Start.
10. Place the calibration target face-down on the scanner glass, touch Start, and scan the page.
After this pass, the calibration is complete.
Calibration will fails if print quality is not good...ensure that print quality must be in order..
Once calibration successfully done, restart printer several times & verify start button light, if its green every time 'u' re success. if not cleaning required for CCD which is major work & not suggestable..
Posted on Oct 12, 2013
SOURCE: unable to use ADF. Red light under start button.
Examine the full paper path of the ADF. Look underneath as well. Could be something as simple as a staple caught deep inside.
Posted on Mar 16, 2010
SOURCE: no poweraftereplaced the adf scanner in hp color laserjet 4730mfp
Make sure you reconnected all of the cables when you replaced the scanner. Unplug and reseat the connectors -- maybe one of them is not seated all the way in.
Posted on May 28, 2010
Dec 31, 2013 | HP LaserJet 4730mfp All-In-One Printer
Nov 12, 2013 | HP LaserJet 4730mfp All-In-One Printer
Sep 13, 2011 | HP LaserJet M1522nf Multifunction Printer...
Jun 27, 2011 | HP LaserJet 4730mfp All-In-One Printer
Dec 23, 2010 | HP LaserJet 4730mfp All-In-One Printer
May 27, 2010 | HP LaserJet 4730mfp All-In-One Printer
Mar 16, 2010 | HP LaserJet 4730mfp All-In-One Printer
Dec 02, 2009 | HP LaserJet 1022 Printer
Feb 10, 2009 | HP LaserJet 2840 Printer
460 people viewed this question
