There are two possibilities. here (both in case it power on but no spin )..One ..there is no noise at all ..and in this case the motor is burned out ..and you will need a replacement ..and the second case..there is a noise from the motor ..but the platter will not spin ..and in this case you need a replacement for the belt ..cause the drive is belt based..
If you do not have power at all ..than you might need to check the fuses..There has to be located somewhere near the access point of the power cable ..and usually are labeled..and look like a plastic screw lid ..which once removed..will expose the fuse..
For a belt fault ..take a look here for a replacement
http://www.ebay.com/sch/i.html?_nkw=audio+technica+turntable+belt+&_cqr=true&_nkwusc=audio+tehnica+turntable+belt&_rdc=1
In case the motor is out ..you may consider if it will worth the repair...unless it has a sentimental vale for you ..and in this case you have to contact the manufacturer for a replacement or ..if they do not make this kind anymore..you may consider buy a second hand one for parts ..
