SOURCE: i cannot connect to internet with my wireless usb adapter
you need to get into your routers settings and make sure that DHCP is enabled to automatically assign ip addreses and also go to the properties of your wireless adapter and ensure obtain ip address automatically is checked. Turn off any WEP or WPA security until you have all the connections, make sure that the adapter is on the same wireless channel as your router and that all the pc's are on the same network workgroup eg WORKGROUP or MSHOME. It may be as simple as right clicking on your wireless adapter icon in control panel>network conections and select connect.
SOURCE: Cannot connect my wireless adapter to Belkin wireless router
Check and see if this setup guide matches your device?
Setup Guide
If it does we can probably search for more information.
Did you configure your router using WEP, WPA security (using passphrases) on your router?
Did you enable MAC address checking on your router?
SOURCE: Belkin N1 Wireless not STAYING connected
change channels to 1-6-or 11. Make sure you change all of them.
SOURCE: No Internet Connection after Installing Norton 360
Some messing up taken place with the registery now use some good registry software to deal with it..
Thanks,
Scott
