Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Bagger support bar does not fit my yth2348 mower. tried several supports and nothing fix.
Posted by roy_streetma on
Michael Shadrick
    New Friend:
  • 176 Answers
Check the USERS Manual
Posted on Aug 30, 2011
How to install a Husqvarna leaf bagger
The bagger installs by using the supplied bracket on the rear of the tractor. Mount the frame of the bagger onto the bracket. then connect the discharge tubes using the spring connecters. Flip open the lid and slide the bags into the frame.
Sep 04, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Grass catcher doesn't fit
Do you a plate to attack to back of tractor with 4 bolts.
Feb 04, 2014 | Husqvarna Tractor Bagger
Sears riding mower will not start after it killed.
first thing you need to do is check and make sure the blades are disengaged set the park brake and try to start it again all newer mowers will not start without parking brake set or depressed and blades or pto in the off position good luck
Oct 07, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Yth2348 sway bar fell off and I can't see where it connect's?? Help
hi there wdycle 7
pauly46 here
please check out web site and download manual it has exploded digram and will show what you need see pages 19 and 20 these have location of sway bar and fittment
http://www.husqvarna.com/ddoc/HUSO/HUSO2010_NAen/HUSO2010_NAen_YTH2348_532441716.pdf
cheers hope it helps
pauly46
Aug 06, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Hello, my craftsman 13.5hp ohv rider will not start. The left front tire deflated here 1 week ago, so I left the mower in the back yard for 2 nights, which happened to be very cold with frost. After fixing...
Remove battery and bring inside. Let it set for a few hours to warm up, it may be partially frozen. If you have a battery charger, after it has warmed up fully, charge it at a slow rate (1A) overnight. Put it back in the mower and try again. If still nothing, the battery may be ruined.
Oct 09, 2010 | Craftsman 1 Bin Grass Bagger
Need a manuel with instructions how to attach MTD model 190-182-190 bagger to my toro mower
Your MTD bagger may not fit your Toro mower..Check with your dealer.
Oct 05, 2010 | Mtd Garden
I just purchased a poulan xt 38" riding mower and am wondering if this is the correct bagger for this. My model # is PXT12538.
If your tractor is 2006 or newer then yes this is supposed to fit. This bagger will also fit some craftsman mowers.
Jul 22, 2010 | Husqvarna #QCT38 960720001 38" Dual Bin...
Mtd bagger not bagging ...its 100 deg today grass is short and the tube keeps clogging up w /grass it wont go into the bagger .how can i fix the problem??? chris
The MTD web site has a list of items to check:
http://support.mtdproducts.com/cgi-bin/mtd.cfg/php/enduser/std_adp.php?p_faqid=68&p_created=1027017166&p_sid=tq2XafGj&p_accessibility=0&p_redirect=&p_lva=214&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTQsMTQmcF9wcm9kcz0wJnBfY2F0cz0wJnBfcHY9JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9YmFnZ2VyIGNsb2dz&p_li=&p_topview=1
Aug 10, 2009 | Gaiam Reel Lawn Mower Grass Catcher
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
108 people viewed this question
Top Husqvarna Garden Experts
bryan st
Marvin
Marvin
dannydoesita
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
