Hi OE in your dishwasher is a
drain error and dishwasher not draining issue usually occurs due to kinked
drain pipe, clogged drain filter or drain pump. First make sure that the drain
is not clogged and remove clogs if present. If no visible lint is present then
remove the lower front access panel to check the drain filter and drain pump
for any clogs, you'll need to clean the drain filter and drain pump completely.
Also, check for any food pieces stuck near the pump impeller & clean the
chopper assembly. If the issue
returns after cleaning then the drain pump assembly should be replaced. Hope
this helps...please post back for further assistance. Daniel
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
