Question about Sony KP-57WV700 57" Rear Projection HDTV
KP57wv700 Sony rear projection. Screen turns completly red after warm up. I took the back off to look at the color globes and red and blue seem to be the same brightness, the green seems weak. Is the green globe the problem? I've read something about a bad solder connection somewhere which if I knew where that was I could correct it. I've also seen some prices on these color globes and if it's not a solder connection...the tv will be out at the curb for next garbage day..
6ya staff
SOURCE:
TVtechmaniac
David Makowski
  • 140 Answers
SOURCE: Blue Screen
Your blue crt has a short - you can verify this by unplugging the socket from the blue crt and powering up the set and you should see a yellowish looking picture with just the red and green crt's operating. You can try turning down the screen control pot (B) for blue with the blue crt on (just to the point where you no longer see retrace lines in the picture on a blank input)Sony has had a lot of problems with the crt's on these models and sooner or later all the crt's will fail - For a permanent repair all must be changed.
Posted on Aug 20, 2007
Lashawn Robinson
  • 1153 Answers
SOURCE: Red Green Blue Across The Screen
Yes, especially big screen. It sounds like convergence is out of lign. Try menu and straighten out, wait until set is warm first.
Posted on Dec 06, 2007
TONY BIGNELL
  • 147 Answers
SOURCE: Sony KDF50 rear projection TV with a Blue tinge (haze) on screen
You have a problem within the light engine. This a hugely expensive. If the set is not too old you could contact Sony and see if they will help you out. Otherwise it is not eceonomical to repair
Posted on Mar 30, 2009
miklosb
SOURCE: Arched blue lines across screen of Sony 63" Rear Projection TV
Had this problem bout 2,3 years ago...it was fixed in about 5 minutes with the help of this article
Tonight I have to do this fix again..the blue lines came back about a week.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
I strongly urge you to save the web page locally on your hard drive or print it out and place with the tv manual....
Good Luck..
Posted on Jun 19, 2009
Anonymous
  • 68 Answers
SOURCE: blue shaded areas in the corner of the screen
you have a bad light engine call Sony and see if it is one of the ones they extended the warranty on.
Posted on Sep 16, 2009
My hitachi 57f510 has been turning orange am I able to fix this and how.
If I remember correctly, There are 3 projection globes in the back of a rear projection TV. I would say 1 of the globes has failed which is gives you an incorrect colour balance on the screen. There is usually a red, green and blue globe. Its probably either of the blue or green one which has failed. Someone else on fixya may be a bit more conversant with rear pro TV to confirm this.
Apr 19, 2015 | Hitachi Televison & Video
KP57WV700 - Blue Lines Across The Screen
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 26, 2009 | Sony KP-57WV700 57" Rear Projection HDTV
When tv is on it just loses all color but blue
the tubes are going out on you,probably time to replace them
Oct 27, 2008 | Sony KP-51WS500 51" Rear Projection...
KDP-65WS550
· Sony Picture tube recall
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
or try this
Sony Too green,red or blue
Feb 06, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Sony KP57WV700
Get them back out there and and make them fix the problem. Obviously it was not properly serviced. $800 for a repair that didn't take is a rip-off. If they refuse, report them to your local BBB and post negative feedback on ripoffreport.com, angieslist.com and as many other places you can come up with.
Jan 05, 2008 | Sony KP-57WS500 57" Rear Projection...
Black Screen with vertical lines down the side?
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
The screen turns red after being on for about 30 minutes
or
Nov 10, 2007 | Sony KP-65WV700 65" Rear Projection HDTV
Blue screen
Sony KP-57WV700 57" Rear Projection HDTV Logo
51 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
