SOURCE: Thud sound, once per rotation
that do fall under defective workmanship...but you have to look in your owner manual,,under your warranty page...i know if its stainless your covered..onthejob
SOURCE: The on line instruction for replacing Maytag dryer
My 1955 edition of the Maytag top popped off because it used the spring clamps you refer to. If there are screws there, you will have to remove them. Once the top is up, you will see how to remove the front. If you can get this far, the rest of the job will become self evident (I think) .If you need more help, let me know
a
SOURCE: my unit doesn't drain. isn't there a
There is no drain on some of the newer ones,that plug into a 110 outlet.Look on the bottom of the case,to the rear of the unit.If it has a drain the case will have a small hole in it.
SOURCE: washer does not start, replaced
Hello there and welcome to fixya
I am sorry to hear that you are having problems i will post some information on some more parts that need to be tested ok?
Washing machine is dead, wont start
Obviously the first thing to check is that the socket is supplying
power by plugging another appliance in such as a lamp. It is less likely
to be the socket but you'd be daft not to check it out before calling
an engineer as it does occasionally turn out to be a faulty wall socket.
This is only necessary though if there are no led indicator lights lit
up on your washer as any light that's on shows that the machine is
getting a live and neutral supply from the socket.
The second thing to check is the fuse in the plug. Either put the fuse
into something else and check the appliance still works or try another
fuse that you know to be OK in the washer. Make sure you use a 13 amp
fuse and never by-pass a fuse! If both of those are OK,
then the most common cause for a washing machine that wont start is the
door interlock, particularly if the mains lights on the washing machine
has come on, but nothing works. However, the fault could also be in
wiring to the door interlock or even the door catch not activating it
properly, or the on off switch or the main control module. With some
Indesit and Hotpoint washing machines even an open circuit heater or
motor can cause the entire washing machine to stop working except the
led lights.
You need to know what you are doing to trace this type of fault so if
it isn't the wall socket or the plug you'd be better getting an engineer
to trace it. Do not work on a live washing machine. Engineers should
use a continuity test meter to trace faults with the washing machine
unplugged and never test with a live washing machine.
