It sounds to me like your a-coil is freezing up on you. If you can do it yourself the refrigerant pressures need to be checked as this problem can often be caused by low levels in the system. I would also check return air filter and clean or replace as needed.Shut off power to outside condenser and wash out with high pressure water or air. It may be needed to clean the fins and coils on the a-coil too if you can get to them.Best of luck and thank you.
