Question about Philips GoGear HDD1830 MP3 Player
GoGear raga it says memory is full delete some contents how can isolve this problem
Posted by edwinstima on
3 Related Answers
YourZEN
YourZEN
  • 820 Answers
SOURCE: my gogear raga philips mp3 player - how do i know
Next site shows the support site for all available RaGa players in the UK:
http://www.support.philips.com/support/search/search.jsp?fetchWhatData=CountryCategoryData&_dyncharset=UTF-8&userLanguage=en&userCountry=gb&searchValue=raga
When the player is bought in the UK, select your player from the list to get the matching support.
When having the RaGa player in another country, select yours in the page top on the right and enter the word raga in the bar next to [Find now]. Next choose the exact model number.
Look for the Quick Start Guide how to connect and charge the player.
e.g. Quick Start Guide for RaGa player SA1982 on page 6.
To register see the Register your product phrase in the page top of the support site: on the page showing up you can create an account.
I hope this gives all the information you are looking for.
Posted on Dec 28, 2009
Gyula Lacz
  • 486 Answers
SOURCE: "memory is full conect to
You can repair your device using this steps:
Please install Philips Songbird software on your computer and then launch the program.
If you don"t have it can be downloaded from Philips website.
In the Philips Songbird menu bar (at the top), click on the Tools pull-down menu and then select Repair My RAGA.
Follow the on-screen instructions to complete the repair procedure.
I hope it will be successful.
Thanks.
gylacz
Posted on Apr 28, 2011
hunter19_46m
Curtis Sewell
  • 7482 Answers
SOURCE: my philips raga ipod does not work need to delete
Hi
Deleting Files,Pictures,Videos,Audio Books, Apps,etc. from MP3 Player/Ipod
BIG WARNING: DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
ONE MORE BIG WARNING: BE CAREFUL AND DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Please take time to rate me
Posted on Sep 04, 2011
Cannot transfer MPEG-4 (.m4a) files
Hello, friend, you may convert the m4a file to mp3 file for a try, I know GOGEAR RAGA MP3 Player supports mp3 well. If you don't know how to do that, this audio converter will help you a lot.
http://www.freedvdripper.net/audio-converter.html
Hope it helps. Contact me if you have any other question.
May 27, 2013 | Philips 4GB GoGear RaGa MP3 Player
My philips raga ipod does not work need to delete some content
Hi
Sep 04, 2011 | Philips GOGEAR SA6045 MP3 Player
My Gogear Raga is "stuck"
I just had the same problem now and what I did was hit the reset button. I did this out of desperation as I was not home when this happened. Luckily, when I turned it back on, all my files are still there!
Yaaaay! :D
Aug 30, 2011 | Audio Players & Recorders
My GoGear Raga MP3 Player is detected in my PC but when the time i access it. a pop-up will display and prompt "Please insert a disk into drive [g:]" and i look at the properties the file system...
if your mp3 player is compatible with memory card insert one then connect the player to the pc
if not, it's obligatory that it shows 2 drives: one that can not be opened ( the drive "g" in your case ), the other is the one you can use to copy your data & files
Jul 02, 2011 | Computers & Internet
Thanks.
gylacz
Apr 28, 2011 | Philips GoGear SA2RGA MP3 Player
I have the PhilipsGo Gear Raga, How do I erase music I no longer want?
You will need to connect the gogear to the PC and see the files inthe player. Now select the files to be deleted one by one and delete them.
Once the work is finished remove with safe removal.
Sep 30, 2010 | Audio Players & Recorders
On my Gogear Raga 2GB I can't make a playlist. (SA2RGA02). With WMP I can synchronise the music, but there's no playlist on the device. All the music is stored in different folders on the Raga and not in...
Sync all the songs you want onto the raga via 'songbird'.
Stay connected, then go to windows explorer, identify your device. Then in 'Music', make folders for your playlists. Manually transfer (drop and drag) your songs to the required folder/playlist.
When using the raga use the 'folder' option. Works as playlists.
grayza
Jul 10, 2010 | Philips GOGEAR SA6045 MP3 Player
It will not let me add videos any more and my memory is not full i still have space
The GoGear allows you to make voice or FM radio recordings and saves the recordings to the internal memory. The internal memory is limited and the GoGear may show the message "Memory Full" when trying to save recordings. When you receive this message, plug the device into the computer and delete any extraneous files or files you no longer want to keep on your device. This will free up memory so you can save more recordings or place additional music files on the GoGear.
I recommend you to reset your device If the solution above didn't solve the problem :.
Take a small object like a paper clip and use the edge to stick into the small reset button on the side next to the usb connection .
Or Try [ power + volume up button & hold for 3 seconds ]
Your mp3 player has two types of memory in it. The hard drive (where the music and photos are stored) and the Ram (where the firmware and active files are temporarily hosted).
When you soft reset your GoGear, it flushes the RAM, and restarts the operating system (which is why the contents of the hard drive does not get erased).
You can "hard reset" the device, by formatting the drive and resetting it to factory defaults in the Settings field. This is the closest thing to a "hard reset: that's available with an HD based MP3 player.
PLEASE DON'T FORGET TO RATE !
Apr 18, 2010 | Philips GOGEAR SA6045 MP3 Player
Phillips go gear vibe 4gb mp3 says drm license expired owned it for only one month
Philips gogear vibe 4gb says its full then it says to delete some content. I deleted every thing and it still says that.
Mar 07, 2010 | Philips GOGEAR SA6045 MP3 Player
My gogear raga philips mp3 player - how do i know
Dec 28, 2009 | Philips Audio Players & Recorders
Philips GoGear HDD1830 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
aliasger yq
Jean Sintulaire
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
