Question about EliteGroup ECS G31T-M Motherboard - Quad Core Support, Intel G31, Audio, Video, PCI Express, 10/100 Ethernet LA
Powers up, but no display or keyboard indications.
Posted by rarboleda on
LTFubar
    New Friend:
  • 102 Answers
If nothing shows on the screen and no beeping from the computer that means a bad motherboard or cpu.
if it beeps, how mant and the type of beep, short / long?
Posted on Aug 29, 2011
  • 3 more comments
  • rarboleda Aug 29, 2011
    There are no beeps or sounds of any kind. No display and no sound. Just the fans running.
  • LTFubar
    LTFubar Aug 29, 2011
    try removing and reinstalling the cpu, but is sounds like a dead board. sorry.
    I submitted this info to ECS and they tell me I am using the wrong CPU. It is an "Intel Core 2 Quad Q6600 (SLACR)". The school bought 20 of them with this motherboard and this is the only one that does not work.
  • LTFubar
    click on cpu buttonhttp://www.ecs.com.tw/ECSWebSite/Product...
    the table does not list the CPU but it should work as others almost with almost the same spects are listed.
    Thanks for the help. I found a program on line that shows the cpu information. http://www.cpuid.com/softwares/cpu-z.htm...
    All I needed after that is the determine the cpu codes. Was it SL9UM or SLACR? Found that here on this site.
Screen will not come on
Check
(1) Power
(2) Battery
(3) LEDs on keyboard
(4) Fan or other indicators for life
(5) if keyboard and sound is of, try to connect external display.
(6) if you isolate the problem to screen, determine if the resolution is set correct and the display driver is updated.
(7) check LCD screen flex cable connector to motherboard.
(8) replace LCD is the screen or the cable or both if that is the issue.
Aug 01, 2016 | Computers & Internet
No LCD Display on Dell Vostro 1700 - 17"
It sounds like you have been pretty thorough trying to resolve the lcd problem
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Dec 13, 2012 | Dell Vostro 1700 Notebook
Acer laptop switched on light up on switch but no screen display
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode,
Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue.
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop.
hope this helps
Hope this helps
Nov 24, 2012 | MSI P45 Neo3-FR (MS-7514-010) Motherboard
I have HCL Ezeebee desktop computer when we boot the system monitor, keyboard, mouse blink for a while and monitor (HCL) show 'no signal' message, and keyboard num lock led not display mouse i
No signal at the monitor indicates (if you know the monitor is working ok) a failure of the graphics chip or graphics card, The lack of indicator light on the num lock LED and the lack of power to the mouse would indicate that there is a major issue with the motherboard.
you can try using another monitor to confirm the problem lies with the graphics, and in the case of the keyboard and mouse, swap them for a usb version, if they work, the Ps2 ports are probably damaged.
I'd be thinking of replacing the motherboard
May 19, 2012 | Computers & Internet
Any help for beeping acer laptop when opening..thanks
g'day!
i would like to know how many and the kinds of beeps? there are what they call beep codes which indicates what kind of problem the your laptop is experiencing: here are the common ones:
0 beep = no power, loose card, short
1 short beep = normal,POST (Power On Self Test), your computer is ok
2 short beeps = POST error, review screen for error code.
continuous beeps = no power, loose card, short
repeating short beeps = no power, loose card, short
1 long, 1 short beeps = motherboard issue
1 long, 2 short beeps = video issue
1 long, 3 short beeps = video display circuitry
three long beeps = keyboard/keyboard card error
one beep, blank, incorrect display = video display circuitry
aside from the 1 short beeps, you need to take your laptop to a technician to have it looked at.
cheers mate!
jelo a.
Aug 21, 2011 | Computers & Internet
I have a Gateway 7010715R (KR-0532) HID keyboard. I have lost my on-screen display for lock key indicators because the keyboard does not have indicator lights like a wired keyboard. What controls this...
This OSD is controlled by your keyboard driver. If you were previously getting On Screen Display and you are not getting it now, it is possible that you might have disabled the startup items from mscofig. In that case enabling the startup items will resolve this issue. Or else re-install the driver and software of keyboard to resolve this issue.
Sep 05, 2009 | Computers & Internet
Casio WK-3300 intermittent display problem
I had the same problem after my keyboard sat for awhile unused, with the display not working, which probably indicates kamangaezeki was right about it being a flash problem. The solution for me was to take the batteries out, unplug the ac, replug it, and then power on while holding the transpose button. This appears to have reset the display, works fine now
Aug 21, 2009 | Casio WK110 Portable Keyboard
My Logitech EX110 wireless keyboard has no light indicators for CAPS LOCK and NUM LOCK. Should it have those indicators?
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
  • Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
Mar 27, 2009 | Logitech EX110 SP CORDLESS Keyboard/Mouse
Cap Lock on or off
Feb 11, 2009 | Logitech Cordless Desktop EX110
IBM R51 display to base unit connection cable problems
your computer affected by some viruses, scan w/ anti virus
Dec 26, 2007 | Lenovo ThinkPad R51
EliteGroup ECS G31T-M Motherboard - Quad Core Support, Intel G31, Audio, Video, PCI Express, 10/100 Ethernet LA Logo
135 people viewed this question
Top EliteGroup Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
ChinthakaJ
ChinthakaJ
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
