Question about RCA RS2531 CD Shelf System
I lost the manual for my RCA shelf sound system. model number RS2531. Do you know where I can download a free manual?
Posted by dhobson509 on
5 Related Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: RCA RS2531 display says Overload and won't function
Start by disconnecting the speakers, turn the volume to minimum, and see if the unit still shuts down. You might have a shorted speaker or wire. If the trouble continues, either the amplifier integrated circuit has gone bad, or some other component failure is activating the shutdown. I can't suggest any specific parts you might check because many things can cause the same symptoms. You'll need to have the unit looked at by a commercial servicer.
Posted on Feb 20, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: I lost the user manual for my RCA rs2534, is there
CLICK HERE for a PDF version of your manual.
It is stored on my personal FTP area - and will be deleted in 24hours.
Please save a copy to your Computer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 09, 2009
mrphoneguy
Harold Wagner
  • 7 Answers
SOURCE: lost remote
Amazon sells a remote for about $13.00
http://www.amazon.com/RCA-262535-REMOTE-CONTROL/dp/B001ICTKQO/ref=sr_1_18?ie=UTF8&s=miscellaneous&qid=1248891499&sr=8-18
Posted on Jul 29, 2009
ABRsvcs
  • 4234 Answers
SOURCE: Describe your RCA Audio Shelf System Problem
If you have cleaned the CD lens using a cotton swab and alcohol and it continues to skip, try cleaning the rails that the optics assembly rides on using a clean cotton swab. Sometimes the grease on the rail gets contaminated with dust and that causes the optics assembly to stick a bit. The motor that moves the optics assembly will generate more torque and when the optics finally move, they overshoot the target position. This results in a loss of information that you hear as a skip.
If neither suggestion works, please update this and we'll try another option.
Thanks,
Dan
Posted on Dec 30, 2009
hmerchant110
AliTech110
  • 7191 Answers
SOURCE: I have a RCA rs
You can download and print the instruction manual in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Posted on Sep 05, 2010
How to connect RCA powered super woofer to RCA RS2531? The system is working with headphones but how ever I tried to connect the speakers there is no sound.
Only one way will work and it's in the manual, page 2.
http://www.retrevo.com/support/RCA-RS2531-manual/id/19240ci975/t/2/
Page 6. "Press Subwoofer..."
The unidentified "RCA powered super woofer" probably has a manual, too.
Web search "(product) manual"
Aug 07, 2011 | Audio Players & Recorders
Set up clock
Hi, you can use the manual to know how to set the clock for RCA RS2605 CD Shelf System.
Download the manual at the below link.
You can download the user manual in PDF format by clicking this link.
* You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Jan 13, 2011 | RCA RS2605 CD Shelf System
I need a copy of users manuel for RCA shelf stereo Model # RS2605
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Jun 01, 2010 | RCA RS2605 CD Shelf System
Feb 20, 2009 | RCA RS2531 CD Shelf System
RCA 2130i manual needed
Hi, go to http://www.retrevo.com/support/RCA-RS2130i-manual/id/19240ci969/t/2/ register (it's free) and themn you can download your manual in pdf format
Dec 09, 2008 | RCA RS2130i Shelf System
RCA 2656 bookshelf music system cd door
I have a similar stereo system and accidentally put two CD's in one tray and it got stuck and could not open. What I did was unplug everything from the unit and took off the side panel. After some careful fiddling I got it to open. You could try something like that.
Dec 30, 2007 | RCA RS2531 CD Shelf System
Speaker Balance Trouble
Can you reset this unit to default settings?
Oct 05, 2007 | RCA RS2531 CD Shelf System
RCA RS2531 CD Shelf System Logo
35 people viewed this question
Top RCA Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
