3Com NBX 3102 IP Phone Logo
Posted on Aug 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I get the message: 3Com Model 3102- Wait for NCP M We have never seen this before and it is after a power outage. Our server is running. What is NCP?
Anonymous
Level 3:
President:
  • Master 3,278 Answers
  • Posted on Aug 29, 2011
Anonymous
Master
Level 3:
President:
Answers
3278
Questions
0
Helped
785139
Points
9440
Hello.
NCP stands for Network Call Processor. There is a problem with communication. Since your server is running, reset your router (disconnect power, wait a few minutes, then reconnect) that supports your IP phone.
Hope this helps.
Reset 3com 3102
Hi Chirag,
On the web interface, use
1 Click System Maintenance > Purge Data.
2 Click Purge Database
This ll do fact reset.
HTH
-Karthik.
3com 3102 not working
try 192.168.2.1 / 192.168.2.0 / 192.168.0.1
hope it works.
enjoy
3Com 3102 phone dial tone but won't dial out
As long as someone hasn't been poking around in the phone system, this is a phone company issue. I have seen this many times and it has always been a carrier issue. Typically with PRI's or integrated access analog lines.
Problem! INternet (DSL) line is down so I have put in a 3G USB Dongle which has restored internet.... but somehow some of the phones on our NBX 100 have lost connectivity - just say 'Wait for NCP' on...
The problem would be more than just internet in order for the phones not to work. they just need to be plugged in to a switch on the network to be able to communicate with the phone system and the other phones. Probably a switch or the DSL router if it has a built in switch.
How do I change the time?
I'm pretty sure that's set at the server level so that all the phones are synced, not at the phone itself.
No network problems 3com phones can't get connected to dhcp
Assuming you are talking about remote phones, you need to program the NCP (call processor) IP into the phones manually or add option 187 to your DHCP scope. The phones are able to DHCP the just also need to know what the IP address of the phone system to connect to is. If the phones are on your local network then this is all unnecessary. They work at layer 2 locally and don't need to use an IP address or DHCP.
The sytem says its waiting for NCP and has the NCP light light. How can I reboot or fix the problem
This means that the phone and the NCP (Network Call Processor) in the phone system aren't communicating with each other. Multiple problems can cause this. Things to check:
1. Network cable - Is it plugged in, and to the right port?
2. Phone died
3. Is there an available license? (3100 series phones)
4. Is there a network switch problem causing a loss of communication through whatever switch that the phone is plugged into.
When someone call 3Com NBX 3102 IP Phone we cannot hear them talking, but they can hear us. I tried it on three 3Com systems and same thing happens. We get problems like these often and we are just...
If the phones are only 6-8 months old you should be calling 3Com. those phones have a 1 year warranty and once you register them they will help you troubleshoot and replace them if needed. Can you provide more detail? Do you have any network issues while this is happening? Does speakerphone work but the handset doesn't?
We recently experienced a power outage and unable to log ont
In most cases you just have to reset your modem and/or router, to do this just unplug the modem for the mains for 2 minutes, plug it back in and wait another 2 minutes for it to settle down, then you can try to reconnect to the server.
Regards.
2answers
Remote Phones
I have only been able to get our phones to work when there is a VPN connection between the two locations.
Dave
Top 3Com Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
john h
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
