SanDisk Sansa Clip MP3 Player Logo
Posted on Aug 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sansa clip+ ......dropped about 400 songs.....tried to download after cleaning out old songs, but to no avail....tried drag/drop from playlists AND library......the few songs that are left, when on skips 2-4 songs when changing tracks. Is it the clip, or the program from rhapsody?
Anonymous
Level 2:
Sergeant:
  • Expert 181 Answers
  • Posted on Aug 29, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
181
Questions
Helped
18467
Points
520
Only thing I can think of is to start over, and hope there is no problem.
Then you will know if you screwed up, and don't know how, or if the thing is messed up.
Try a different method of loading tunes onto it.
try everything
PLEASE RATE THIS ANSWER
1helpful
How do you put music on the SanDisk Sansa Clip MP3 Player
1. First, you have songs saving in your computer.
2. You have 2 ways to put music on the Sandisk Sansa Clip:
2.1. Plug device into computer, Drag and Drop music from your computer into "Music" folder of the Sandisk Sansa Clip.
2.2. Use Windows Media Player in your computer to transfer songs to your device; Plug device to computer, open Windows Media Player, click on Sync tab, drag and drop music into "Drag items here " on the right side of the windows media player, click on Start Sync button.
Good luck
I am trying to delete songs on my playlist. I
connect your sansa to the computer and via usb cord check computer the hardrive letter e,f,d, whatever right click that letter and then format. this will delete all the songs. or you could open windows media player click sync and then drag and drop songs from your computer to your sansa or visa versa.
How do I download music to my Sansa Clip MP3 Player
First, you have songs into your computer. Then, plug the device to computer and use one of two ways to download music to your Sansa Clip:
1. Select songs you want transfer, drag & drop them into Music folder in the device.
2. Use Windows Media Player: plug device to pc, open windows media player, click on Sync tab, drag and drop songs selected to Sync List space (on the right side of wmp), click on Start Sync button to transfer.
Good luck
Downloading music to my MP3 player, how do I do it. I have the music on my computer and I move to the MP3 player but when I disconnect it does not display on my MP3 player
For transfers to Sansa Clip see page 11 of the pdf manual [page 9]:
http://mp3support.sandisk.com/sansa/UserManual/CLIP/CLIP_UM_English.pdf
When using the drag and drop method in Windows
music has to be dropped in the Music folder of the player.
Using Windows Media Player 11:
In Library or Sync mode:
1. Create a playlist e.g. "MyPlaylist"
2. Put music in the playlist
3. Save the playlist
In Sync mode and the player having connection:
4. Move the playlist e.g. "MyPlaylist" under / to the device
5. Start synchronizing with Start Sync
6. Wait until al files have been transferred:
a message appears when you can disconnect .
When you need more help just post a comment.
1helpful
I can't get a playlist onto my Sansa m240. I tried the method described on this site, and the name of the playlist came up, but said it had no files.
Creating Playlist
To create a playlist for Windows Media Player, follow these steps:
1. Launch Windows Media Player.
2. Clear the List pane by clicking the Clear List pane button.
3. Click the arrow below the Library Tab then select Create Playlist.
4. Type in the name of your Playlist.
Loading Content 14
5. Click Songs from Library then drag them from the Details pane to the List
Pane.
6. To rearrange the songs, drag them up or down in the List pane.
7. Click Save Playlist.
Transferring Playlists
To transfer playlists to your Sansa player, follow these steps:
1. Connect your Sansa player to the computer.
2. Select Sync digital media files to this devices using Windows Media
Player on initial connection.
3. Right-click on Your Sansa Player, then select Set Up Sync.
Loading Content 15
4. Select Personal Playlists from the drop down menu on the left pane.
5. Highlight the playlists you want to transfer to your Sansa player, click Add,
then Finish.
6. Synchronization will start as soon as you click Finish. To see the Sync
progress, click on Sync Results.
1helpful
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
2answers
How to download
well there are some sites where download songs for free. when you download the songs go to my computer click the drive your usb is in (as soon as you do that sometimes you might also have to do that) then you see your files cut and paste the song anywhere there and then take out the usb plug your head phones and find the song you out in.
Can't download playlists to Sansa e270
Did you try dragging the songs individually??
2helpful
7answers
I can't put songs on my Sansa Sandisk e250....
Hey to get music onto the Sansa e250R you have to plug the Sansa into the computer. Next go to mycomputer. Then onen ethier sansa or Removable Disk(F:). Then take the songs you want and drag them on to the white space under photos and vidos and all that other files. DO NOT PUT IT IN A FILE.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
