You can usually find your WEP key from any computer that uses the router. Open the Network Options (in the control panel as Network Connections) and find your wireless. Right click it and go to properties, then Wireless Networks. Search for the SSID (network name) of your wireless router, right click and go to properties. The WEP key should be in plain text somewhere in that dialog box.
If you can't find it there, you'll need to find/set it through your router's web config. Plug in the router via an ethernet cord directly to your computer (through one of the numbered ports, not the internet port). Wait for a minute or two for it to get connected, then follow these instructions.
Hope I answered your question!!
You can find it by logging into the router itself. Open a web browser, Visit the routers ip address
Typically 192.168.1.1 or 192.168.0.1
If neither ip works, Click Start > Run > Type in cmd, Click OK, In the command window type ipconfig /all and press enter, Use the Primary dns or Gateway ip that it gives you and visit that in your browser.
Your router will ask for a password (hopefully you remember), If you never set one the username and password combo might be
admin with the password of password
admin with the password of admin
(blank) with the password of password
You will be able to find your wep settings in the wireless setup portion of the router..
btw wep is not secure encryption anymore, I would suggest wpa or wpa+psk
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
X-BOX
On the x-box you will need to connect to the wireless network now.
Open the main Interface of the X-Box.
1. In the Xbox Dashboard, go to My Xbox and open System Settings.
2. Select Network Settings, Configure Network.
3. On the Basic Settings tab, select your wireless settings.
4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
5. If your network has wireless security, enter your WEP or WPA key.
6. Try to connect to Xbox LIVE again.
Trouble connecting to the internet on X-box ,Play station or WII ?
You can try to reduce the MTU settings on the router. if the MTU on the router is set to 1500 then change the MTU to 1365. Also you will need to open the ports on the router.
For X-box port numbers are - 53, 80-88, 3074 .
